why is my material schedule listing the same portion of wall 6 times?
I had itemized every instance selected and area grand totals, but I've never
seen a schedule replicate the same items?
What could be the issue?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
When you select one of the walls and click on show, do those walls highlight at the same spot or they are reference to another location?
do you have links in your model? check that the Include elements in Links on the Fields tab isn't checked.
Howard Munsell
There are 6 different materials in that wall type. Show the Material Description column here.
