Revit 2023 "select" in print range not opening sheet view list
RogK
RogK
Hi all
As per the title, Revit 2023 "select" in print range not opening sheet view list doesnt work anymore..
Have uninstalled and completely reinstalled 2023 (including the complete "clean install instruction listed by Autodesk). same with printers etc..
But to no avail.
Older versions of Revit work fine..
Hope someone can help next option is to completely re set up PC... massive task for simple issue with no guarantee of success
R
ralphdenhaan
Can you try to change the default printer in Windows? And then restart Revit?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
RogK
yes have a number of times, even removed one..
seems more of a 2023 bug, had a few of late,
have all the latest updates etc.. even tried a full and clean re-install
ralphdenhaan
What version of Revit 2023 do you use? Maybe try to update it to 2023.1.2 if that is not the case?
RogK
we re ran it (had done previously) and the addinIssues update thats about 2 weeks newer and surprisingly it worked.
go figure, thanks Ralph
