So when you create the deployment using the Autodesk website it asks for a Revit.ini file and then gives you the deployment. However, I want to make a few changes to Revit.ini and can't find it in the deployment image folder. If I want to make any changes I have to go back to the Autodesk website and generate a new deployment?
The definition of insanity is doing the same thing over and over again and expecting different results
