Revit 2023 Deployment - Where is Revit.ini ?
EATREVITPOOPCAD
EATREVITPOOPCAD
So when you create the deployment using the Autodesk website it asks for a Revit.ini file and then gives you the deployment. However, I want to make a few changes to Revit.ini and can't find it in the deployment image folder. If I want to make any changes I have to go back to the Autodesk website and generate a new deployment?
The definition of insanity is doing the same thing over and over again and expecting different results
EATREVITPOOPCAD
I don't see where it says it is located on the deployment image for installation. I know where to find it on the PC once Revit is installed...
EATREVITPOOPCAD
I'm dumb... Was searching in the wrong deployment folder that looked very similar (Autodesk Formit)...
Anyway the .ini file is located in this directory of the deployment image:
\image\RVT_2023_en-US\CustomUserFiles\SETTINGS_INI_FILE_PATH
