Revit 2023 crashes when using Visibility Graphic Overrides with links
curtisridenour
Advisor Advisor
Message 1 of 9
curtisridenour
Please see the attached 2023 files to recreate the issue. All models are OOTB Revit templates.
  1. ARCH model has MECH model linked in.
  2. The MECH model does not have Workset1 linked into the ARCH modelcurtisridenour_1-1655949583199.png
  3. The CAD file is linked into the ARCH model.curtisridenour_2-1655949650278.png
  4. Open visibility graphics on any plan or RCP view and change the Import Category overrides and hit ok.curtisridenour_3-1655949766483.png
  5. An unrecoverable error occurs and Revit closes.curtisridenour_4-1655949862305.png
    The error/crash does not happen if Workset1 is linked in from the MECH model. Any help or guidance would be greatly appreciated.
Replies (8)
Message 2 of 9
michael_coviello
Autodesk Support
Autodesk Support
Hello @curtisridenour
Thank you for reporting this and providing detailed steps.  I've been able to reproduce this and have reported to our team for investigation.  I'll reply to this post with an update.
When you crash, is there a CER report number given?
I look forward to your reply and thank you for reporting this problem.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Message 3 of 9
curtisridenour
Hi Michael,
Thanks for the reply. Please see the Error Report below.
Date/Time: 2022-06-28 15:55:36 -06:00
Application: Revit.exe
Error: Integer divide-by-zero - code c0000094 (first/second chance not available)
Crashed Module Name: RevitDB.dll
Exception Address: 0x00007ffcd508ae16
Exception Code: c0000094
Exception Flags: 0
Exception Parameters:
Message 4 of 9
curtisridenour
Also got this error loading in worksets
Date/Time: 2022-06-30 11:28:21 -06:00
Error: C++ EH exception - code e06d7363 (first/second chance not available)
Crashed Module Name: mscorlib.dll
Exception Address: 0x00007ffdac474fd9
Exception Code: e06d7363
Exception Flags: 1
Exception Parameters: 19930520, f6880f1f40, 7ffcfe07bcb8, 7ffcfbf30000
Managed Exception Type: System.Runtime.InteropServices.SEHException
Managed Exception Address: 0x000002326943e9d8
Message 5 of 9
michael_coviello
Autodesk Support
Autodesk Support
@curtisridenour Hello , Here is a knowledgebase article to track the problem which our team is working on for a future release of Revit.  Please post back if the workaround helps.
I look forward to your reply and if this helps to solve the problem!
Crash when editing visibility graphics of imported categories in Revit | Revit 2023 | Autodesk Knowl...
For the new crash,  Were you loading worksets within the linked model and is there a CER report number?
Michael C
Message 6 of 9
curtisridenour
Thank You Michael
Message 7 of 9
curtisridenour
We are still experiencing issues with 2023 crashing. Whether we have all the worksets loaded or not from linked files. Is there any new development or a hotfix coming for this? We end up losing alot of time on our 2023 projects these days.
Message 8 of 9
curtisridenour
new Error Report when adding RVT Link parameters to a sheet list even when all worksets were loaded from all linked models.
Date/Time: 2022-10-12 13:37:00 -06:00
Crashed Module Name: KERNELBASE.dll
Exception Address: 0x00007ffd3cbb4fd9
Exception Flags: 1
Exception Parameters: 19930520, 8fb451c130, 7ffc95e1abb8, 7ffc950d0000
Message 9 of 9
michael_coviello
Autodesk Support
Autodesk Support
I'm sorry to hear this is still happening and the workaround does not help; The problem here may be slightly different.
Please create a support case and include the files to reproduce the crash and a specialist will be glad to help.
Contact Customer Support | Autodesk Knowledge Network
Michael C
