Revit 2023 changes to PDF prints when using PDF Creator and Deltek hub creates border space.
FrankHolidaytoiling
FrankHolidaytoiling
I am having issues whenever I try to print to pdf using the Deltek hub create renditions function. It might be related to printing using the free PDF Creator however I tried using the microsoft printer and it also had the same affect. I am using the DLM Integrator 2023 addin and it is creating a rendition that has a blank border. It is similar to when you dont print 100%, so i am thinking a print setting has changed perhaps in one of these components in revit 2023.
If anyone has a similar environment and issue pls let me know.
Can you use Revit's Export to PDF?
