How can I show only a finish of a wall to be new construction
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
AidanHawkins
181 Aufrufe, 1 Antwort
Below I have my existing wall (External finish with no internal Finish) and what I want for my new construction (External and Internal Finish)
I don´t want to demolish the whole wall, I just want to add a finish
How can I show this in my plans (highlighted in yellow below) that this is the only new construction
1 ANTWORT 1
Nachricht 2 von 2
tiho
als Antwort auf: AidanHawkins
Create a new wall type that is made up of just the finish layer. For example, 5/8" gyp. board only. Then, you can have the existing wall be existing construction and the 5/8" wall be new construction.
You can use the JOIN command to join the existing and the new to make sure your door and window openings show up.
