Revit 2023.1.4 crashes when I want to change a material keynote.
davy_degryse
Message 1 of 8
davy_degryse
I can select the 3 dots and select a keynote, but I can't enter a keynote myself by typing.
Updating the file is not an option, as we work with several firms on this project.
Anyone has an idea plz ?
Replies (7)
Message 2 of 8
vitorbortoncello
If directly entering keynotes causes a crash, try updating the keynote file directly:
  • Open the keynote file in a text editor.
  • Add or edit the keynotes as needed
If you are working in a workshared environment, try creating a new local file from the central file. Sometimes, local files can become corrupted.
Did you like this post? Don't forget to like and accept as solution!
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 8
It's been addressed on this forum before. The workaround is to go through the back door, so to speak. Tag some element with a Keynote Material Tag that has a label that reports that Parameter and then populate that Parameter in the Tag directly.  Doing so will populate the Parameter under the Material's Identity Tab.
Message 4 of 8
handjonathan
Hi @davy_degryse
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 5 of 8
davy_degryse
I found out that changing the material keynote in a schedule works !
Message 6 of 8
Yes! Like I said above, the workaround is to populate those Material Identity Parameters through the "back door", such as through a Tag or a Schedule.
Message 7 of 8
colinSRA
Looks like update 2023.1.5 is available on manage.autodesk.com now; supposed to fix the freeze issue...
Message 8 of 8
stephen.spikings
2023.1.5 seems to fix the initial problem but when I duplicate a material and its asset, and then try to edit the asset name, Revit is still freezing. Closing the material editor and then reopening to edit the material asset name still results in a freeze. Closing the project file and then reopening allows the material asset name to be edited.
