Revit 2022 Query - Copying an existing model with multiple design options into a new project file created from a different template
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to be able to copy an existing Revit 2022 model which contains multiple design options into a new Revit 2022 project, created from a new template, but cannot work out how to do this. I cannot simply do "save as" as the problem that I am trying to overcome relates to existing families loaded into the original model - when trying to load new additional families, these will not load because there appear to be conflicting shared parameters - this is the error message that I get:
The shared parameter "05c57bab-7370-44ed-a733-fae972e935d4" cannot be added with name "GlazingAreaFraction" and type "Number" because it conflicts with the existing name "FractionSurfaceVitree" and type "Text".
I have purged the existing model to try and get rid of the families that are causing the problem (which aren't actually used in the model) but this doesn't solve the issue, and I have therefore resorted to creating a new template file which does not include the specific problem families.
I have tried to copy and paste the model into a new project created from the updated template but it does not retain either the existing / proposed phasing nor any of the design options. I have also tried to link the original file to the new project and bind it, but again it does not retain any of the phasing or design options.
Maybe this is just something which is not possible?
