Hello all,
I have some trouble with creating a sloped glazing roof from a flat roof modified through 'Modify Sub Elements".
The sloped glazing roof would be modified to become the structural framing system for the roof, instead of picking lines to add structural beams.
Is revit unable to generate a glazing system for this roof form? Attached screenshots illustrates the issue.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I don't think you can change a modified elements roof to a sloped glazing. Create a mass and create a curtain system by face, or roof ( sloped glazing type) by face, or divide surfaces and assign a curtain panel pattern based.
