Revit 2022 on Parallels Desktop 16
Message 1 of 9
I have a new MacBook Pro. I just installed Parallels Desktop 16 Standard Edition, then Windows 10 ARM-64, then Revit 2022. After Revit was fully installed, I opened it, but got an error message saying "An unrecoverable error has occurred..." I looked into it and it seems like the system requirements aren't met, even though they should be. What can I do to fix this?
Replies (8)
Message 2 of 9
It seems like this question has already been answered elsewhere, so nevermind.
Message 3 of 9
Update:
Revit 2022 is running on my M1 Macbook with the latest Windows 10 ARM-64 update, build 21390.
A little bit slower than I am used to, but it is working.
Message 4 of 9
How did you get that build? Latest version of Windows for ARM I've been able to find is 21354.
Message 5 of 9
Windows Insider Program, it was a preview build. I was able to run Revit 2021 and Revit 2022 without any problem. I'm currently trying the Windows 11 preview which is also working without issue. I also realized that I only had 2vCPUs on Parallels, upped that to 4vCPUs.
Message 6 of 9
f.annoscia1XRNMD
So does Revit work well on parallel desktop Windows? Can you confirm this? I should rent a Mac 32 GB RAM for a few months, I would like to use the parallel for Revit (and Autocad). What does "I only had 2vCPUs on Parallels" mean? Thank you.
Message 7 of 9
I have found that with the work that I do as an Architectural Draftsmen, Revit 2021 and 2022 work quite well. Correction on the vCPUs (virtual CPUs), I didn't change that, the Pro Edition of Parallels has 32 vCPUs standard. What I did change was the maximum number of the MacBook's CPUs that it could use.
Message 8 of 9
I have a Macbook Pro with M1-chip. I just installed Windows through Parallels as told in their instructions. Now checking the "Updates" in Win 10 it says I have the build 21354.1-version. Revit is crashing with the same message as above, "An unrecoverable error...."
What to do next? Do I need to go through all this told above with Dev Channel or what? Can I install an earlier version of Revit just to get going meanwhile?
Thx for response!
Message 9 of 9
ssukkau
Community Visitor
Community Visitor
I have been able to run Revit LT 2022 with no problem on my desktop w/ Parallels but I cant open regular Revit, it just says it's initiating and then nothing happens...
