Tag Path of Travel Lines
PhilvK
Advisor Advisor
PhilvK
How do I add 'Mark' to a Path of Travel Line tag?
Edit the tag family and add a label for Mark.
smulqueenQWLRP
What tag family did you use to start this? I'm unable to find the specific one, and generics don't contain the correct parameter values I need for my tag.
There should be an OOTB path of travel tag. If you can't find it, not a big deal, just start from a generic tag and change it to Path of Travel tag category then you will have all parameters from Path of Travel to create labels.
leilani4F9NF
HOW DO YOU CHANGE THE TAG CATEGORY?
