Revit 2022 Linework Tool Not Permanent
ggolombekCLUGQ
Message 1 of 10
ggolombekCLUGQ
Hello all,
I have a question about the Linework Tool being used on a Linked CAD file underlay. When I use the tool to make invisible lines (I want to turn off only certain portions or areas of linework in the CAD file), it works in the view I am in and for the current session. But when I close the revit cloud file and re-open it, all of the linework items re-appear. Is there any way to make this action stay on for the view permanently? Or is there another way to do this without having to change the background cad file ? (The layers that this small portion of linework is on would affect the entire background cad file if I use the visibility graphics to hide a layer).
Thank you for any tips or assistance.
G.
Replies (9)
Message 2 of 10
Preserve Graphic Overrides
Message 3 of 10
ggolombekCLUGQ
Message 4 of 10
@ggolombekCLUGQ wrote:
Barthbradley, that box is checked.
That box only keeps/removes overrides via VG and Query, has nothing to do with using Linework tool.
To make it work, link the DWG in an in place model family such as a Generic Model, then the Linework tool overrides stay intact.
Message 5 of 10
Message 6 of 10
ggolombekCLUGQ
How would you do that?
Message 7 of 10
Architectural tab > Component drop down > Model In-Place > choose a category (suggest Generic Models) > Link DWG  normally > Finish.
Message 8 of 10
ggolombekCLUGQ
So you would have to do this before the drawing is linked in the revit file? I ask because my cad drawing is already linked, and if I have to redo a new link it will undo many sheets and layer settings (tons of work).
Message 9 of 10
Unfortunately yes.
As a general recommendation, always link DWG in a family (in place or loadable) instead of directly in the model.
Message 10 of 10
ggolombekCLUGQ
There has to be another way to do this. You should not have to do a 'special' (meaning linking a file inside of a generic family in the model) type of linking for a CAD file for the linework tool to work.
