Revit 2021 - Vault 2021 add-in?
Message 1 of 9
Is Revit 2021 going to have a Vault 2021 add-in? We installed Vault 2021 and Revit 2021 today but there is no Vault Ribbon within Revit. Is this something that will be added later?
Replies (8)
Message 2 of 9
DarrenP
it works fine here
do a add/remove on the vault client from the windows control panel
DarrenP
Message 3 of 9
I'm not sure I follow. We have Vault Client 2021 installed, opened and working. When we open Revit 2021 the vault tab on the ribbon is not there and I can't find anywhere to show it/turn it on. When we opened Inventor 2021 the vault tab was on that ribbon.
Message 4 of 9
DarrenP
this is what i mean
You can install the revit Vault add-In using these steps:
  1. In Windows, open Program and Feature.
  2. Find Autodesk Vault [edition] [release] (Client).
  3. Click Uninstall/Change.
  4. Click Add or Remove Features.
  5. Check the Revit Add-In.
  6. Click Update.
DarrenP
Message 5 of 9
Awesome! Thank you for spelling it out for me, that worked perfectly. Very much appreciated!!
Message 6 of 9
dineshrajan.albert2PKNX
  1. Hello,
I tried this below solution, but still i didn't get vault add in in revit
we are using both 2021version of vault and revit
  6. Click Update.
And tried reinstall of vault client, but nothing happened, so anyone could you please help me
Message 7 of 9
kevin.smedleyNBQT6
Same... Typical Vault feature change adding Revit did not work.
Message 8 of 9
kevin.smedleyNBQT6
This is what I found a solution to the Vault Ribbon Add-in not loading to Revit from a clean system. Opened the company Autodesk Account and created a deployment from the new features in the products area. When setting up the Revit through the Autodesk Account, I chose most all of the extended add-ins and created the Deployment. Downloaded the deployment and then Ran the exe. Feeling good about it, I made sure all the updates were added and performed a re-boot.
Next, opened Revit and there was NO Vault ribbon. Devastated I began another search for answers. I came a cross an article or forum doc or other that contained 2 sentences about the Generative Design for Revit. I looked and I had added it to the deployment. I then uninstalled ALL of the Revit and its add-ins / extended features.
Autodesk Account, created another deployment for Revit but left it simple without the add-ins. After running the deployment, I changed the Vault add/subtract features adding Revit. BOOM!!! That worked... I then through the Desktop apps, updated the appropriate add-ins/updates except for Generative Design. If there is a need, then I will add it in, but until then we are up and running.
- Kevin
Message 9 of 9
kevin.smedleyNBQT6
WAIT!!! Second and third systems without Generative Design are showing the original situation of NO-Vault Add-in.
Still LOOKING for answers...
