Revit 2021 Not Printing Correctly (Bad Text + Missing Sheets)
cfordLTUBQ
Observer Observer
cfordLTUBQ
Observer
Observer
Having issues printing to pdf from revit. There are text issues, missing sheets, some blank sheets, etc... Nothing consistent from page to page or even from print to print. Doesn't matter if its one sheet or multiple, different page sizes. Different revit files, different templates, different PDF drivers. Uninstalled revit, Bluebeam, etc...It looks like this has to do with a Windows 10 update but I don't have the other options to uninstall the Windows 10 update. I know four other people across two organizations having this same issue. Anyone else have the same and get it fixed???
I believe this is the update causing the issues:
But when I go to uninstall there is no option for that update so not sure which one to uninstall
3rd post today about this. I think Autodesk is aware of it.  I suspect a fix is already in the works.
@lim.wendy?
lim.wendy
Hi @cfordLTUBQ,
I see that you are a new member of the Autodesk Community. Welcome and thanks for your question.
Other users are reporting printing issues after some Windows update.
See this threads: https://forums.autodesk.com/t5/revit-architecture-forum/revit-not-printing-some-text-and-images-prop...
Can you try the suggestion from the threads above.
I have shared the threads with the product team and will reach back out.
Thanks, @barthbradley for letting me know.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
lim.wendy
Hi @cfordLTUBQ ,
We have the issue reported in the following article:
Printing to PDF causes text to distort and be off center in Revit
The solution is also posted in the same article.
Wendy Lim
Rails Summit
