REVIT 2020 - One particular room not showing in plan views
do-da
Message 1 of 8
do-da
I have one room in the project that would not show in any plan-views (just one room)...I cannot tag this room in any plan. All the other rooms show correctly with tags... the room shows in sections, but not in any plan... I can delete that room, and make a new one, and the problem still exists, duplicating views does not make a difference either... You can not see that room with "reveal hidden elements"... I can make another rooms other places in project and they do work correctly, but not in that particular place... The room in enclosed and the area is correct... any ideas?
Replies (7)
Message 2 of 8
Are you sure that it's the correct level?  The balcony seems much wider on the plan than the section.
Message 3 of 8
It is. You can notice it by where the stove is.
Message 4 of 8
"I can delete that room, and make a new one, and the problem still exists..." Have you tried deleting from the schedule? Rooms can only be true deleted from there.
Message 5 of 8
do-da
Of course it is, I have been working on that project for 3 months now, so I know it quite well... the first building was almost the same (apartment groups were copied between projects), but I did not experience the same problem with the first building. And the problem is only on this level (on the first lever everything seems fine). This particular apartment is not copied from another project.
Message 6 of 8
Yes, you are correct. Some things to check.
  • Check if there is a plan region there.
  • It could also be a filter applied in your VG.
  • Is the workset on?
Message 7 of 8
do-da
I am not working on worksets and no filer is applied to any view  - and why would it filter this particular room from all type of floor plans and area plans and not sections? (I can try to see if it shows in ceiling plan...)
Never used plan region before, it would be strange if that room was not in it, but all rooms around are... I can make new rooms on any side of this room, but not inside this particular area... all rooms have same computation heights...
Message 8 of 8
do-da
I found it 😀
It was that wall component that was messing up with the room.
I changed it to not room-bounding and it worked.
My room suddenly appeared in planviews.
