Revit 2020 Family Description - Project Schedule Bug
Berat_Dogan53CT8
Message 1 of 10
Berat_Dogan53CT8
Hello everyone,
When I use the "load to project" button from within the family in Revit to load the family into the project, the description part appears correctly in the schedule. However, when I open the project and call the family into the project, the descriptions for different types appear the same. I would greatly appreciate any assistance with this issue.
Replies (9)
Message 2 of 10
Message 3 of 10
Berat_Dogan53CT8
I have no issues with loading the family.
Message 4 of 10
admaecc211151
Do one of the following:
Click Overwrite the existing version. The family definition is overwritten (geometry) but the parameter values assigned in the project remain the same.
Click Overwrite the existing version and its parameter values.
Maybe it cause by these different. Try not overwritten the parameter values.
...Or maybe it just cause by a view. Some problems with view (schedule is a view) would disappear when you restart the file.
Message 5 of 10
Berat_Dogan53CT8
I tried what you suggested, but the issue still persists.
Message 6 of 10
azad.Nanva
is this correct ?
I think this have a problem.
Message 7 of 10
Berat_Dogan53CT8
Yes, that's correct. If I call it from the table, the Russian characters get corrupted because it is in .csv format.
Message 8 of 10
Berat_Dogan53CT8
Additionally, there is no problem when I perform the same operations in higher versions of Revit. For example, Revit 2021.
Message 9 of 10
azad.Nanva
no i don't think so, your key is InkaCode not InkaO6...
show me the formula ,
if you change the type in type name or change the "INKA Code" all the variable change except the "INKA 06..." so i think this is the problem.
Message 10 of 10
admaecc211151
Would that be help if you change the format of CSV from UTF-8 to ANSI?
Since I'm using Chinese version more, I need to check the txt file formats often.
