Revit 2020 Export to DWG issue
Message 1 of 9
I run Revit 2020.2 I have huge issues exporting to DWG. I get an error message that says the File is already open.
(See Attachment). I am sure I have all the settings right as it did work on older versions. I  am positive that nothing but Revit is running or open. I have tried r-booting but no luck there. I have researched the other posts re the same problem but no one appears to have an answer.
If anyone can help, please as I desperately need to solve this issue.
Thanks Steve
Replies (8)
Message 2 of 9
Never had this issue myself and I export to CAD a lot.  Have you tried Exporting to maybe your Desktop/with a different Name?
Message 3 of 9
hmunsell
is this on a Home PC or an Office PC?
my office locks down our PC's pretty tight. Your office may have the C:\ blocked from creating files in if your not an admin.
Howard Munsell
Message 4 of 9
Thank you hmunsell & Barth. This is my home PC so no admin issues & yes I have tried exporting to different locations. The only option re the file name is the long or short options. I have had success in the past using the short option but that is not working this time. I am totally lost with this & it seems from the many other posts there is no obvious fix.
Message 5 of 9
Can you post a link to these posts you are reading?
Message 6 of 9
hmunsell
it is only happening with one particular model or does it happen with any Revit model you want to export to DWG from?
Howard Munsell
Message 7 of 9
Thanks H. It is happening with all models. It is obviously a problem with my PC as I run Revit on my new laptop & the same file converts to DWG without any issues. I don't have A'Cad on the laptop but that shouldn't make any difference to the conversion.
Thanks Steve
Message 8 of 9
Henrik_Nobile
... I don´t even try to open! Since every DWG I export from Revit 2020.2 results in a 3KB autocad file I just know its for nothing 😞
/ Henrik
Message 9 of 9
syman2000
I heard many people have these problem. This is an older post and some Revit view just stop publishing. I was wonder if Autodesk ever address these issue.
https://forums.autodesk.com/t5/revit-architecture-forum/error-exporting-revit-to-dwg-file/td-p/72070...
