Revit 2020 - Door family height and width parameters won't act as "typical"
mcoquereau
mcoquereau
Hi there,
I modeled a door family and now am trying to set types of various dimensions.
I'm surprised and confused to see that the OOTB "Height" and "Width" parameters won't keep the evalues defined for each type. Ex: when I create a type with a specific width, all the other types are changed to that width.
I checked the parameters were typical and the tickbox of "by instance" in the ribbon was unchecked. I also tried to lock or not them in the family type panel, with not success.
Of course, a shared parameter would be a quick fix, but it doesn't feel right to use a workaround for such a basic thing. I'm pretty sure I'm missing something here, so good occasion for me to learn a new trick!
Family attached below (it's in french, but shouldn't be a problem for the geniuses out there!)
Thanks!
SteveKStafford
You haven't provided any parameters that different types can influence. Your formulas in Width and Height are equivalent to locking the size from change.
You need a width and height parameter that each type can provide to your formulas to act on. The type will define width and height and then your other "width" and "height" logic can respond to that. See attached.
Steve Stafford
mcoquereau
Note to myself: add values in the "Value" column, and the formulas in the "Formulas" column.
SteveKStafford
Absolument
Steve Stafford
