Hello I am uisng Revit 2022.
I am working on the interior elevations of a project with a linked model that contains all walls, floors, ceilings etc.
At first the linked file DID show up within elevations and playing with Visibility overrides I was able to set up several views without major issue. After returing to the project a few days later, (the linked file has been updated and reloaded), the linked file is completely missing from all elevations. Even when revealing hidden elements the linked file is not there.
I have tried all three far clipping options, with no change. Removing the crop does not reveal the model either.
There must be a simple way for this to work?
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Steve Stafford
When you open the link model, does it contain any content? Also when you link in your model, did you use origin to origin or center to center? Try zooming extent and see if the model is shifted accidently.
Can you open the linked model? Have a look at how the model is organized and see if there are any clues to be found.
Are any worksets closed in your model?
What happens if you link the model to a new blank project?
If a view template is assigned to the elevations try removing it and assigning any other to "reset" "refresh" the view(s).
Steve Stafford
@david9TMST wrote:
Hi Snyman,
The linked file is set to the same origin point. Using the view extents and zooming out I can see topography from the linked file when revealing hidden elements. Walls, ceilings and floors are still not showing.
Does the topo from the linked file appear at the correct location relative to your model?
Have you opened the Revit link and see if the wall, roof, floor, door and window are in there?
Also does your link have design option?
Link display is set to custom.
The linked filed has no design options.
See snippet for display information. And view of elevation with hidden element turned on and the crop off.
You have existing phase but show new. So any existing will be turned off. I would set the phase filter to show all or show complete.
Why are you using override link Custom? What happens if you restore the By Host View setting?
Also for Phase Filters (for By Host Settings) to work they must be named Identical to each other in both files. If there are any differences in the naming of phase filters then the ones that are different won't apply to the linked model correctly.
Revit doesn't apply the phase filters of the host model to the elements in the link. It "looks" for a matching phase filter in the linked model and when it finds one it applies "that" filter to its elements in the view.
Steve Stafford
