Revit 2020.2 graphic issues
Message 1 of 9
I am currently working on a project on Revit and I am encountering an graphic issue very frequently lately.
It usually occurs 3-5 minutes after opening this project and honestly it is driving me nuts. (see attachments)*
Has anyone of you ever dealt with this kind of issue or is it me? if so, could you please tell me how to fix it?
best regards
Vincent
*graphic_issue.png is how it looks like and graphig_issue_2.png is how it looks like when I restart it
Replies (8)
Message 2 of 9
RDAOU
Is the Graphic Card/GPU on you PC/Laptop certified? can check here --> Autodesk Certified Graphics Hardware
Did you try update graphic card drivers?
Did you try disable hardware acceleration (R>Options>Hardware)
Message 3 of 9
I have a NVIDIA Quadro P2000 installed on this computer, which is verified for revit.
Also there aren't any new drivers to install for my graphics card und turning off hardware acceleration just slows down the programm but doesn't solve the problem for me.
Is there a chance, that my file may be corrupted? I checked the file while opening it a few times now but it seems plausible to me. Also i just did a model check. so I'll let you know if this helped or not.
And thank you for your help 😄
regards Vincent
Message 4 of 9
Update:
I just set a few anchors in this project when all of the sudden my object looked like this (see attachments). i cant move using the pan tool and I cant zoom in or out. Also when I rotated using the viewcube everything dissappeared and now it is just blank. luckily I have a backup file.
I think it has something to do with the viewcube because I only encountered this graphics issue right after rotating using the viewcube.
Message 5 of 9
RobDraw
Is it just one file or does it happen in all files?
Have you tired recreating the 3D view?
Rob
Message 6 of 9
Well i can't tell if this happens in other files too, since I only worked with this file on revit.
And what do you mean with " recreating the 3D view"?
Message 7 of 9
Does the issue occur in this 3d view or in multiple views?  RobDraw is suggesting that your view may be corrupted.  If so, recreate the 3d view.
Message 8 of 9
ennujozlagam
how many GB of ram installed in your computer? try to do a clean uninstall and reinstall again your revit program and see if helps. thanks
Message 9 of 9
er
I had the same problem and my default 3D view would get progressively worse the more i worked in it. I found that setting the view to perspective instead of orthographic solved the problem. I could switch back to orthographic mode then and work away.
