Revit 2020.2.4 update does not work on Windows 7
Basam.Yousif
Advisor Advisor
Basam.Yousif
I have a case with a Revit 2020 on Windows 7. It works fine until you install the latest update 2020.2.4 which kills Revit and it no longer opens, displaying this lovely message:
Here is the full text of that msg:
Problem signature:
Problem Event Name: BEX64
Application Name: Revit.exe
Application Version: 20.2.40.65
Application Timestamp: 607f4a59
Fault Module Name: Utility.dll_unloaded
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 607f4643
Exception Offset: 000007febb2b2bf6
Exception Code: c0000005
Exception Data: 0000000000000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: cb1a
Additional Information 2: cb1a1314db354cc0fc6c007a412e6ce6
Additional Information 3: d0a1
Additional Information 4: d0a155c922a511688191ebfa61f50566
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
HVAC-Novice
Windows 7 support from Microsoft themselves ended in 2020. I assume if not even MS supports it, other vendors won't support it either.
Time to upgrade to W10.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
