Revit 2019 Worksharing issues
Message 1 of 30
We seemed to be having a very consistent issue with revit 2019 and files that are workshared.  They all have a issue talking back to the central file.  We get prompted with "can not communicate with central file" notifications as well just lots of "blue wheel" time while working in the files.  We aren't having any issues with 2018 files or below.  It seems to be isolated to workshared files in 2019.  It doesn't seem to matter if the file was upgraded from 2018 or created new.  It also doesn't seem to matter how big or small the project is either.
Replies (29)
Message 2 of 30
ennujozlagam
Have you try to install the latest updates from autodesk or create a new central file and see if helps. thanks
Message 3 of 30
Viveka_CD
Hi @Anonymous
Sorry to hear that you are facing issues.
Can you see this article: Error When Accessing a Workshared File for recommendations to try and let me know if this helps with your issue?
Message 4 of 30
All machines are on 2019.0.1, which I think is the most current (as of right now)
Message 5 of 30
It doesn't seem to be a network issue as it doesn't effect other versions of revit.  It is isolated to revit 2019
Message 6 of 30
I'm the network administrator in charge of the network on which this issue is occurring. There is no SAN or NAS involved. These files are stored on a RAID5 array on a Windows Server 2012 R2 machine.
Message 7 of 30
And I can verify that there seem to be no network issues aside from this one specific one. All other traffic, and all other versions of Revit are performing as expected. We spent hours on Friday performing benchmarking across the entire network and saw zero issues.
Message 8 of 30
cbcarch
Have you tried running a Repair of the Revit 2019 installations? Sounds like there may have been a corrupt network deployment or something else wrong with the installation.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 9 of 30
Viveka_CD
Hi @Anonymous
Can you share your Revit file, journal and other files for diagnosis?
I can create a private upload folder and a case for your issue.
Let me know, I look forward to your reply update.
Message 10 of 30
Yes, please set up a folder.  I would be happy to send them.
Message 11 of 30
Just an fyi, it is multiple jobs with multiple users.
Message 12 of 30
Viveka_CD
Hi @Anonymous
I've shared the link, let me know if you have trouble accessing the folder.
Please find a collector utility to extract files for diagnosis and the 'read-me' document has the instructions to collect these files.
Let me know when you are done uploading and I will go ahead with the next steps.
Message 13 of 30
FAZIOGREG
Did this happen to correspond to a windows update?  Our machines freaked out a bit recently and were having similar issues, and we had to go in and repair the Revit installations.  It seems to have done the trick.
Message 14 of 30
RobDraw
It's most likely a setting in 2019 that is different from the previous versions.
My first thought is "File Locations". Maybe Revit is looking for something it can't find.
Rob
Message 15 of 30
Viveka_CD
Hi @Anonymous
Did you have a chance to upload these files? We can investigate further once we have your files to test.
Message 16 of 30
I can't seem to upload files to that folder.  I got the container, and I have run it.  But when I go to upload the files it created it doesn't seem to work.
Message 17 of 30
@Viveka_CD wrote:
Hi @Anonymous
Is this post still being monitored? We've been unable to get the upload to work.
This is still an issue for us.
Message 18 of 30
Viveka_CD
Hi @Anonymous
Yes, this thread is being monitored.
I changed the permission for the upload folder. Please let me know if you can upload the files now.
Message 19 of 30
No I'm still not able to upload.  Here is an image of the page that i see.autodeskupload.JPG
Message 20 of 30
Viveka_CD
Hi @Anonymous
Can you drag and drop contents?
Do you have an alternate location to share the files?
