Removing background with rendered Image
I have attached my image output below.Is there any way to get only image ?
why did it come actually?Please help
Thank in advance.
loboarch
If you export the rendering as a PNG file type the background will be "removed" as an alpha channel.
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-1742C9AA-6BB1-4A3A-9923-A42AA3E927EC#GUID-1742...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
ennujozlagam
Hello, use photoshop to remove the background, thanks
FAZIOGREG
First, in the Rendering Dialog, make sure that under "Background>Style" that you select "Transparent" [see attachment].  Then, export as either a png or tif, and you are all set.  It will work just like having the Alpha channel turned off as @loboarch mentioned; meaning that whatever you put behind it in Photoshop will show through your transparent materials.
hdtruelson
Community Visitor
Community Visitor
It's kind of a kluge but you can remove background after the fact with https://dreamgenerator.ai if you sign in you get a few free credits, and there is an AI powered background removal tool. I used it and here's what I got for yours.
constantin.stroescu
render with transparent background
Constantin Stroescu
hdtruelson
Community Visitor
Community Visitor
Lol, of course!
But I figured I would fix it for him.
