Revit 2019 wont open 50mb file
anugouba
anugouba
Hello everyone, I'm having a very serious problem with a particular project file I created a few weeks ago which is about 50mb in size. It's a Revit file created with Revit 2019 but it wont just open, it gets to about 3 percent and then stops moving. I tried other files of the same size and even the ones that are much lager and they all open except this one. The worst thing here is that its a finished project which I'm supposed to have sent to my client. The back unfortunately is gone which is a big mistake I made. I know the whole thing is messy but please help.
Thanks.
Ian
ennujozlagam
hello, try to tick AUDIT before opening the file and see if helps. thanks
Corsten.Au
Try Audit while opening..
Corsten
Building Designer
ennujozlagam
dude, That's exactly what I have said.
Corsten.Au
As far as I can tell, on my defence 🙂
we both replied exactly at the same time..
you were micro seconds ahead..
next time I ll try to become flash.
cheers
Corsten
Building Designer
anugouba
Hi thanks for the response, your solution worked and saved me from tons of trouble. I always see that audit button but never taken time to actually k ow what it does. From now onwards I will not take things for granted. But just out curiosity what really happened, why couldn't revit open the file all this while?
Thanks.
Ian
ennujozlagam
Nice...well done,,,, the credits goes to you it should go to those suggested the solutions. Thanks
