Revit 2019 - Every possible tool is greyed out!!
Message 1 of 8
ALL of the options to select at the bottom of the screen are greyed out in addition yo EVERYThING else!
I am able to zoom in and out of the drawing, open other sheets.  All give me the same response - greyed out
This happened after editing a cloud on a detail, after I selected the green tick to complete the editing (resizing) of the cloud, the cloud disappeared. This have been due to it being past the exceeding the Annotation Crop range?!
Anyways, the Model did not go into Not responding mode, instead it appears to be still active, however, all the toolbars are greyed out!
I can still open other drawings , but can't select any of the objects on the screen.
Almost seems like it has a command that is running somewhere, waiting to be finished.
Hoping I don;t have to shut this session down and lose work!
Basically everything is GREYED and does not respond. I tried typing VG.. nothing happened.
Replies (7)
Message 2 of 8
_Vijay
As you told, i think you are some think edit mode... but I think save as the file for this situation. Hope its helps you.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 8
RobDraw
^This^
Rob
Message 4 of 8
Thanks but as i said.. everything is greyed out.  Ctrl S doesn't work. ZA works, I can even open other sheets in the file!
Message 5 of 8
Solved!
Found a small dialogue window that was buried under several other running programs, on my 2nd display! #duhme
Message 6 of 8
RobDraw
What was the dialog box? Was it asking if you wanted to exit edit mode?
Rob
Message 7 of 8
zachbischoff
This just happened to me. The last save was 30 mins ago. I was starting to get worried. Thanks for figuring the problem out in the past.
Message 8 of 8
RobDraw
Welcome. (?)
Rob
