Revit 2019 Adding Centerline Symbol in Dimension Text using Arial Font
tturnerJBN46
tturnerJBN46
Using Revit 2019 and trying to add Centerline Symbol in Dimension Text using Arial Font. It just shows a box. Does the Arial font not support the CL symbol.
Please advise.
Thanks in advance.
That is not from the font used.  You need a Generic Annotation Family.
If you want to use Arial letters, just create your own family and use C and L letter from the Arial font (see attached family).
Karol_Piroska
Seems to work just fine.
tturnerJBN46
Thank you for the quick response. I apologize for not stating my post clearly. I meant that I wanted to add the symbol in the Dimension Text dialog box. It shows up as a box when I try to use Arial font. I have added an attachment.
Download the family above, load it in your project and assign it to the dimension style's center symbol.
