Revit 2019.1 Render perspective with sketchy lines enabled?
Hi All
Does anyone else have problems rendering with sketchy lines enabled?  is it possible?
Cheers
Corsten.Au
You may try this..You may try this..1. 3d View - change Walls into 100% Transparent
2. To hide the wall lines ( cause its going to look like wireframe ), use invisible lines in " Line Work "
without linework - transparent wallwithout linework - transparent wallwith linework..with linework..
Best luck
Corsten
Building Designer
ennujozlagam
hello, still not possible rendering with sketchy lines. only good for 3d View. thanks
Thanks guys
