I've tried to use wall.location to get center line location of the wall. Is it possible to get the location of the exterior face? It seemed that the wall.location always return center line location of the wall, even if i set the wall location line as finish face exterior.
Thanks.
Hello, are you making dimension? You can use your TAB on your keyboard to select. Thanks
You can change the wall location line anytime..
and for dimension you can choose faces / core / center etc...
if you select similar for dimension , then it should retain the selection for Faces / Wall Exterior / Wall Interior Face..
hell, well done, i'm not the OP here...![]()
sorry for that.. so may similar buttons of " Reply"
no worries. thanks![]()
Are you taking about "Temporary Dimensions" setting under "Additional Settings"?
Modifications to temporary dimension witness lines are saved on a per-session basis. For example, if a default temporary dimension measures the distance between the centers of two walls and the witness line is moved to measure to the faces of the walls, subsequent selection of the wall preserves the location of the edited witness line for that session.
Thanks. I know the way to change the wall location. But I need the ret
@Corsten.Au wrote:You can change the wall location line anytime..
rieve the XYZ location of the wall's exterior.
