Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Revit 2018 Wont open files and can't close File dialog
BlairmackNZ
Message 1 of 21
BlairmackNZ
Hi there. Ive just decided to start using 2018 and the first thing I did was try and open a file using the Open command. This brings up the dialog box but I can't select a file and open it as the PC Bleeps at me. If I try hitting the cancel button it bleeps again. I can't even hit the X as it's beeping well bleeping again. Only way out is to use task manage the end the Revit process.
Has anyone else had this issue. I can open the sample files etc from the main startup window, and create a file from templates, but the minute I browse to a file to open it, it hangs.
Looking forward to hearing if anyone has a fix for this.
Cheers blairmack
Replies (20)
Message 2 of 21
ennujozlagam
@BlairmackNZ hello, try to install latest autodesk updates for Revit 2018 and see if help to fix the issue. thanks
Message 3 of 21
ennujozlagam
or try to clean uinstall and reinstall again using autodesk virtual agent , switch off all your anti virus program and firewall through download and installation. thanks
Message 4 of 21
BlairmackNZ
Hi
Thanks for your suggestions.
Yesterday I did a repair of the installation and this didn't work. I did a clean uninstall and reinstall and this didn't work.
After receiving your suggestions, this morning I did a clean uninstall and install as suggested wit UAC and A/V off. The message at the end of the install said Revit didn't complete installation. I can start Revit 2018, but getting a message that it can't find template directory which of course I can ignore for now, but I'm still getting the same issue in the open dialog box where I can select a RVT file but getting the bleep warning again and I can't get out of this window without ending Revit process.
I checked the install log and the only failures showing were that I have a later version of Dynamo than is included in the installer.
Any other bright ideas? Thanks. blairmack
Message 5 of 21
ennujozlagam
@BlairmackNZhello, sorry about that. Just to check with you is this a first time you install a Revit program on your computer? Has your computer met the requirements to run the Revit program? Don't mind to post your computer specs and screenshot of error messages. Thanks
Message 6 of 21
BlairmackNZ
Hi
Yes this PC is currently using Revit 2017, 2016 and 2015 with no problems.
I don't get any error messages, I just can't select a file and open it. I can open files from the Revit startup splash screen (eg sample files), but as soon as I use the open dialog and navigate to select a file to open it PC bleeps and Revit hangs and I can't get out of Revit without using Task Manager to stop it.
I'm not sure where to from here, but appreciate your help.
blairmack
Message 7 of 21
ennujozlagam
@BlairmackNZ hello, try to contact Autodesk Technical Support maybe they can help you. I assume you are under Autodesk subscription?. thanks
Message 8 of 21
jelwell3QWFZ
Was there ever a solution for this? I am experiencing the same thing and have tried every method of installation and the like.
Message 9 of 21
BlairmackNZ
Hi
I'm sorry to report I haven't found a solution and I still can't use 2018. Not Impressed! I was going to send a request to Autodesk to try and get some technical help, but it appears that even though I thought I was on subscription, my plan is getting changed over at the next renewal but I don't have access to support. Not impressed again!
I'm going back to my reseller and if I can find anything I'll post an update.
Cheers.
Message 10 of 21
Viveka_CD
Hello @BlairmackNZ and @jelwell3QWFZ
Thanks for posting to the Autodesk Revit Architecture forum!
Sorry to hear that you are facing issue with Revit 2018
A few recommendations to help resolve your issue:
  • Please determine if the system requirements are met. Please see HERE for minimum entry level configuration for 2018 products.
  • Secondly see HERE for a tool to find recommended system hardware or graphics hardware and drivers.
  • Have to applied the latest hotfix for Revit 2018, sign in to your Autodesk Desktop app
  • To install updates, open the Autodesk desktop app and click My Updates
  • If you installed any add-ins, I recommend that you disable add-ins and run the clean install again.
Please send us your journal files to troubleshoot further.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome.
Message 11 of 21
BlairmackNZ
Hi
All requirements are met as per minimum.
Yes latest update is installed.
Have disabled all add-ins and reinstalled. Just confirming I can start Revit 2018 and I can open a file from the startup splash window, I just can't browse to a file by using the "Projects" Open or "Families" open button. They both open the same Revit Open dialog and when I try to browse and select a file to open, then hit the open button (bottom right) the same problem occurs with the PC bleeping and you are unable to close out of the dialog with using Task Manager to close Revit.
I've attached the latest Journal file and would really appreciate if you can find any issues.
Regards
blairmack
Message 12 of 21
jelwell3QWFZ
I have already completed these steps. I am running a brand new Boxx machine and have Revit 2014-17 running perfectly. I have updated with the hotfix and installed all updates.
Message 13 of 21
jelwell3QWFZ
Yes, mine is the same and my journal looks almost identical. I can click in but cannot open through the open dialogue. I also tried downloading from the virtual agent and have gotten the same problem.
Message 14 of 21
Viveka_CD
Hi @BlairmackNZ
Good to know that the minimum requirements are met and the updates all set!
Thanks for sending over the journal files. We will troubleshoot and let you know for a resolution.
Message 15 of 21
Viveka_CD
Hi @jelwell3QWFZ
Sorry to hear that you are facing issues.
The details count and even though identical as @BlairmackNZ, we would like to take a look at your journal files and a screenshot of the error if possible.
Looking forward to your reply update.
Message 16 of 21
jelwell3QWFZ
' 0:< Initial VM: Avail 134217376 MB, Used 16 MB, Peak 16; RAM: Avail 60252 MB, Used 56 MB, Peak 16
' 0:< GUI Resource Usage GDI: Avail 9995, Used 5, User: Used 3
'C 06-Jul-2017 10:27:28.198; 0:< started recording journal file
' Build: 20170223_1515(x64)
' Branch: RELEASE_2018_SHIP
Dim Jrn
Set Jrn = CrsJournalScript
'C 06-Jul-2017 10:27:28.198; 0:< ->desktop InitApplication
'C 06-Jul-2017 10:27:28.198; 0:< <-desktop InitApplication
'C 06-Jul-2017 10:27:28.198; 0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2018\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2018\Libraries\US Imperial\Detail Items (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -24 -> 134217352 MB, Used +4 -> 21 MB, Peak +4 -> 21 MB; RAM: Avail -65 -> 60188 MB, Used +11 -> 68 MB, Peak +11 -> 68 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 28
'C 06-Jul-2017 10:27:28.964; 0:< License initialization complete
' 0:< License version: 18.5.4.1
' 0:< ::0:: Delta VM: Avail -180 -> 134217173 MB, Used +31 -> 52 MB, Peak +33 -> 55 MB; RAM: Avail -66 -> 60122 MB, Used +49 -> 117 MB, Peak +49 -> 117 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 52
' 0:< SystemSettings:
' 0:< 8=multiCoreCharacteristic
' 0:< true=isDotNetInstalled
' 0:< 4.6.01586(394802)=dotNetInstalledVersionString
' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -21 -> 134217152 MB, Used +8 -> 60 MB, Peak +5 -> 60 MB; RAM: Avail -14 -> 60108 MB, Used +16 -> 133 MB, Peak +16 -> 133 MB
' 0:< GUI Resource Usage GDI: Avail 9970, Used 30, User: Used 66
'C 06-Jul-2017 10:27:29.280; 0:< manage licensing
' 0:< ::0:: Delta VM: Avail -49 -> 134217103 MB, Used +5 -> 66 MB, Peak +14 -> 75 MB; RAM: Avail -6 -> 60103 MB, Used +14 -> 147 MB, Peak +20 -> 154 MB
' 0:< GUI Resource Usage GDI: Avail 9970, Used 30, User: Used 69
' 0:< License mode: Standalone
' 0:< Status: Your license is non-expiring.
' 0:< Type: Standalone - Locked
' 0:< Usage: Commercial
' 0:< Behavior: Permanent
' 0:< Expiration: None
'C 06-Jul-2017 10:27:31.105; 0:< manage involvement
' 0:< ::0:: Delta VM: Avail -632 -> 134216471 MB, Used +45 -> 112 MB, Peak +37 -> 112 MB; RAM: Avail -36 -> 60067 MB, Used +51 -> 198 MB, Peak +44 -> 198 MB
' 0:< GUI Resource Usage GDI: Avail 9935, Used 65, User: Used 105
' 0:< Setting WPF rendering mode to SoftwareOnly
' 0:< ::0:: Delta VM: Avail -125 -> 134216347 MB, Used +67 -> 180 MB, Peak +67 -> 180 MB; RAM: Avail -88 -> 59980 MB, Used +87 -> 286 MB, Peak +87 -> 286 MB
' 0:< GUI Resource Usage GDI: Avail 9829, Used 171, User: Used 178
' 0:< Autodesk Revit 2018
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2018
' 0:< this journal = C:\Users\jelwell\AppData\Local\Autodesk\Revit\Autodesk Revit 2018\Journals\journal.0054.txt
' 0:< Journal Init
'C 06-Jul-2017 10:27:34.480; 0:< Log Summary
' 0:< .Count
' 0:< ...PendingMessages = 32
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 51
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 8
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
' 0:< BC: 0,0,0
'H 06-Jul-2017 10:27:34.480; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Construction Template=$AllUsersAppData\Templates\US Imperial\Construction-Default.rte, Architectural Template=$AllUsersAppData\Templates\US Imperial\default.rte, Structural Template=$AllUsersAppData\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=$AllUsersAppData\Templates\US Imperial\Mechanical-Default.rte"
Jrn.Data "JournalDefaultViewDiscipline" _
, "Coordination"
Jrn.Directive "Version" _
, "2018.000", "2.154"
Jrn.Directive "Username" _
, "JElwell"
Jrn.Directive "CategoryDisciplineFilter" _
, -1
Jrn.Directive "DisciplineOption" _
, 7677
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
Jrn.Directive "AllowLinkSelection" _
, 1
Jrn.Directive "AllowFaceSelection" _
, 0
Jrn.Directive "AllowUnderlaySelection" _
, 0
Jrn.Directive "AllowPinnedSelection" _
, 1
Jrn.Directive "ThinLinesEnabled" _
, 0
'C 06-Jul-2017 10:27:34.496; 1:< logging master created MasterQueue Session10436_P0MasterQueue
'C 06-Jul-2017 10:27:34.496; 1:< logging started queue minder
'C 06-Jul-2017 10:27:34.496; 1:< logging started worker services
' 0:< ::0:: Delta VM: Avail -57 -> 134216291 MB, Used +27 -> 207 MB, Peak +28 -> 208 MB; RAM: Avail -88 -> 59892 MB, Used +31 -> 317 MB, Peak +33 -> 319 MB
' 0:< GUI Resource Usage GDI: Avail 9828, Used 172, User: Used 178
' 0:< API_SUCCESS { Registered an external service: Name(DirectContext3D Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(SteelConnectionsService); VendorId(ADSK); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Site Insert Service); VendorId(ADSK); ServiceId(c9979a42-11ab-4c25-93e1-abfb50b7be60) }
' 0:< API_SUCCESS { Registered an external service: Name(RebarUpdateService); VendorId(ADSK); ServiceId(a2c22b44-c231-4d3f-b653-b81b6f8be150) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource UI Service); VendorId(ADSK); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Registered an external service: Name(Point Cloud Snapping Service); VendorId(ADSK); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< ::0:: Delta VM: Avail +0 -> 134216292 MB, Used +5 -> 213 MB, Peak +13 -> 222 MB; RAM: Avail -63 -> 59830 MB, Used +15 -> 333 MB, Peak +22 -> 341 MB
' 0:< GUI Resource Usage GDI: Avail 9828, Used 172, User: Used 180
' 0:< API_SUCCESS { Added pushbutton 35011, name Navisworks 2018, class NavisWorks15.LcRevitExportCommand, vendorId ADSK (Autodesk, www.autodesk.com), assembly ./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll }
' 0:< API_SUCCESS { Added pushbutton 35012, name Navisworks SwitchBack 2018, class NavisWorks15.LcActivateSwitchBack, vendorId ADSK (Autodesk, www.autodesk.com), assembly ./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll }
' 0:< ::0:: Delta VM: Avail -246 -> 134216047 MB, Used +68 -> 281 MB, Peak +59 -> 281 MB; RAM: Avail -144 -> 59686 MB, Used +91 -> 424 MB, Peak +83 -> 424 MB
' 0:< To make IFC server work.
' 0:< API_SUCCESS { Registered an external server: Name(Autodesk Drive); VendorId(ADSK); ServerId(baddc547-d952-4d29-ae01-16e71e75aa63); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: ConnectedDesktopDB, Class: ConnectedDesktopDB.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\ConnectedDesktop\ConnectedDesktopDB.dll }
' 0:< Third Party Updater 'CoordinationModelDB: CoordinationModelDBUpdater' registered for all documents.
' 0:< API_SUCCESS { Registering DocumentOpened event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Starting External DB Application: CoordinationModelDB, Class: Autodesk.CoordinationModelDB.CoordinationModelDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\CoordinationModel\CoordinationModelDB.dll }
' 0:< ::0:: Delta VM: Avail -2 -> 134216045 MB, Used +0 -> 282 MB, Peak +2 -> 284 MB; RAM: Avail -11 -> 59676 MB, Used +4 -> 429 MB, Peak +5 -> 430 MB
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default DB Server); VendorId(ADSK); ServerId(bd4f0f53-394a-4468-b37e-1e7949013382); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: KeynoteDBServer, Class: KeynoteDBServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\Keynote\KeynoteDBServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Plumbing Fixture Flow); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshul-Tsal Equation); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Starting External DB Application: StraightSegmentCalculationServersApp, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\StraightSegmentCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Coefficient from ASHRAE Table); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(K Coefficient from Table); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: FittingAndAccessoryCalculationServers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\FittingAndAccessoryCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SteelConnectionsServer); VendorId(ADSK); ServerId(9c209d4a-ec98-460f-bfde-38f17a3443b4); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external server: Name(FramingProfileServer); VendorId(ADSK); ServerId(54e490cd-8809-4dbb-84dd-dc0bc6cb1712); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Starting External DB Application: ExternalResourceDBServer, Class: RvtSteelConnectionsDB.SteelConnectionDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\SteelConnections\RvtSteelConnectionsDB.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Site Linker Utility Application (01673995-d4d5-4c62-a184-98e970ef7805). }
' 0:< API_SUCCESS { Registering PositionsSaved event by application Site Linker Utility Application (01673995-d4d5-4c62-a184-98e970ef7805). }
' 0:< API_SUCCESS { Starting External DB Application: Site Linker Utility Application, Class: SiteLinker.SiteServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\SiteLinker\SiteLinker.dll }
' 0:< ::0:: Delta VM: Avail -5 -> 134216040 MB, Used +3 -> 286 MB, Peak +2 -> 286 MB; RAM: Avail -12 -> 59665 MB, Used +7 -> 437 MB, Peak +6 -> 437 MB
'C 06-Jul-2017 10:27:37.864; 0:< Journal Logger Registered with Application Services, from within CollaborateDB Addon
' 0:< API_SUCCESS { Registering DocumentOpening event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Starting External DB Application: CollaborateDB, Class: Autodesk.Revit.UI.Collaborate.CollaborateDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateDB.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 134216014 MB, Used +9 -> 295 MB, Peak +9 -> 296 MB; RAM: Avail -19 -> 59646 MB, Used +14 -> 451 MB, Peak +15 -> 452 MB
' 0:< GUI Resource Usage GDI: Avail 9828, Used 172, User: Used 184
' 0:< API_SUCCESS { Registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Starting External Application: RaaS, Class: Autodesk.RaaS.RevitAddin.EApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: RaaSApplication.dll }
'H 06-Jul-2017 10:27:38.263; 0:<
Jrn.Directive "IdleTimeTaskSymbol" _
, "0.ExternalEvent"
' 0:< API_SUCCESS { Starting External Application: AutoLoad, Class: AutoLoader.AutoLoader, Vendor : ADSK(), Assembly: AutoLoader.dll }
' 0:< API_SUCCESS { Registered an external server: Name(AutodeskDriveUI); VendorId(ADSK); ServerId(314de911-0991-4787-a0fd-914be9138034); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: ConnectedDesktopUI, Class: ConnectedDesktopUI.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ConnectedDesktopUI.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COORDINATION_MODEL' Executed implementation with implementation from application 'CoordinationModelUI' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\CoordinationModel\CoordinationModelUI.dll'. }
' 0:< API_SUCCESS { API registering command Coordination Model Executed event by application CoordinationModelUI (9817e4a5-0333-4323-b69e-781db5f70005). }
' 0:< API_SUCCESS { Replacing command id 'ID_COORDINATION_MODEL' CanExecute implementation with implementation from application 'CoordinationModelUI' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\CoordinationModel\CoordinationModelUI.dll'. }
' 0:< API_SUCCESS { API registering command Coordination Model CanExecute event by application CoordinationModelUI (9817e4a5-0333-4323-b69e-781db5f70005). }
' 0:< API_SUCCESS { Starting External Application: CoordinationModelUI, Class: Autodesk.CoordinationModelUI.CoordinationModelUIApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: CoordinationModelUI.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_CEA_OPTIMIZE' Executed implementation with implementation from application 'Energy Analysis' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\EnergyAnalysis\EnergyAnalysis.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Energy Analysis (f50a2212-f174-4890-84a9-064c3c835c4d). }
' 0:< API_SUCCESS { Replacing command id 'ID_CEA_OPTIMIZE' CanExecute implementation with implementation from application 'Energy Analysis' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\EnergyAnalysis\EnergyAnalysis.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Energy Analysis (f50a2212-f174-4890-84a9-064c3c835c4d). }
' 0:< API_SUCCESS { Starting External Application: Energy Analysis, Class: EnergyAnalysis.Application, Vendor : ADSK(), Assembly: EnergyAnalysis.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
'H 06-Jul-2017 10:27:38.482; 0:<
, "1.OnIdleTask"
' 0:< API_SUCCESS { Registering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering FabricationPartBrowserChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Show Service in Part Browser
'Show Service in Part Browser
'Show Service in Part Browser CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Starting External Application: FabPartBrowserApplication, Class: FabricationPartBrowser.FabPartBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FabricationPartBrowser.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Duct not defined pressure drop UI server); VendorId(ADSK); ServerId(607992d7-359d-4593-b497-8aa238e2c564); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(9641a039-441e-42e2-93a6-c0e2177cc23c); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific loss pressure drop UI server); VendorId(ADSK); ServerId(d3b5e81d-9b8c-40da-8efb-99dd37fda611); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(25fa8de2-67c4-47d1-91f6-bd6f0803a5ed); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe not defined pressure drop UI server); VendorId(ADSK); ServerId(62917391-e14d-4897-ad0c-05342d71e4f9); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(247265b6-7b71-4147-97c6-cc52b39c12aa); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific loss pressure drop UI server); VendorId(ADSK); ServerId(5978b92a-3f0b-4691-bbc8-caf2fae20a71); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe K coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(cda19b6f-fbd5-4725-a0ce-f159bf5d02fe); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Starting External Application: FittingAndAccessoryCalculationUIServers, Class: FittingAndAccessoryCalculationUIServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FittingAndAccessoryCalculationUIServers.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_IFC' Executed implementation with implementation from application 'IFC override' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\IFCExporterUI\IFCExportUI.dll'. }
' 0:< API_SUCCESS { API registering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< API_SUCCESS { Starting External Application: IFC override, Class: BIM.IFC.Export.UI.IFCCommandOverrideApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: IFCExportUI.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default UI Server.); VendorId(ADSK); ServerId(3ffc688a-bb2e-4145-90ab-9443da02aef6); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: KeynoteUIServer, Class: KeynoteUIServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: KeynoteUIServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Internal Forces Server); VendorId(ADSK); ServerId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Starting External Application: Member Forces, Class: MemberForcesUI.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: MemberForces.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' Executed implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' CanExecute implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Starting External Application: Object Numbering, Class: BIM.Numbering.UI.NumberingUIApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ObjectNumberingUI.dll }
' 0:< API_SUCCESS { Registered an external server: Name(PointCloudSnappingServer); VendorId(ADSK); ServerId(85f4b666-8811-4e3d-9ed4-3d2ae4cd2e4c); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< Third Party Updater 'PointCloudSnappingServer: Snapping Pipe Updater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: PointCloudSnappingServer, Class: PointCloudSnappingServer.Application, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PointCloudSnappingServer.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Starting External Application: PressureLossReport, Class: PressureLossReport.PressureLossReportApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PressureLossReport.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Surface Distribution Server); VendorId(ADSK); ServerId(26046cb6-7954-47a3-ab4f-ee3a7e35a2ec); ServiceId(a2c22b44-c231-4d3f-b653-b81b6f8be150) }
' 0:< API_SUCCESS { Starting External Application: RebarUpdateApp, Class: RebarMorphedServer.RebarUpdateApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: RebarMorphedServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SectionTypeParameterServer); VendorId(ADSK); ServerId(1b91ce46-ddb4-44ec-a942-d45efadde353); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Starting External Application: Structural Section Properties, Class: SectionProperties.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SectionProperties.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_FILE_TOPOSURFACE_CONVERT_TO_LINK' Executed implementation with implementation from application 'Site Linker Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SiteLinker\SiteLinker.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Site Linker Application (26af0fb8-0ceb-46dc-a0b1-79e0208edcdc). }
' 0:< API_SUCCESS { Replacing command id 'ID_FILE_TOPOSURFACE_CONVERT_TO_LINK' CanExecute implementation with implementation from application 'Site Linker Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SiteLinker\SiteLinker.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Site Linker Application (26af0fb8-0ceb-46dc-a0b1-79e0208edcdc). }
' 0:< API_SUCCESS { Starting External Application: Site Linker Application, Class: SiteLinker.SiteExportApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SiteLinker.dll }
' 0:< ::0:: Delta VM: Avail -11 -> 134216004 MB, Used +4 -> 299 MB, Peak +3 -> 299 MB; RAM: Avail -7 -> 59640 MB, Used +5 -> 457 MB, Peak +5 -> 458 MB
' 0:< GUI Resource Usage GDI: Avail 9824, Used 176, User: Used 185
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SPACE_NAMING_UTILITY' CanExecute implementation with implementation from application 'Space Naming Utility Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SpaceNaming\SpaceNaming.dll'. }
' 0:< API_SUCCESS { API registering command Space Naming Utility CanExecute event by application Space Naming Utility Application (02663093-563b-4e2f-b5be-5b75beb2e313). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SPACE_NAMING_UTILITY' Executed implementation with implementation from application 'Space Naming Utility Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SpaceNaming\SpaceNaming.dll'. }
' 0:< API_SUCCESS { API registering command Space Naming Utility Executed event by application Space Naming Utility Application (02663093-563b-4e2f-b5be-5b75beb2e313). }
' 0:< API_SUCCESS { Starting External Application: Space Naming Utility Application, Class: SpaceNaming.Command, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SpaceNaming.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6400, name: , text: Store Design Line Elements, class: RVTFabExchange.StoreDesignLineElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6401, name: , text: Display Design Selection, class: RVTFabExchange.DispalyDesignLineElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6402, name: , text: Clear Design Selection, class: RVTFabExchange.ClearDesignLineElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6403, name: , text: Store Graphics Elements, class: RVTFabExchange.StoreGraphicsElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6404, name: , text: Display Graphics Selection, class: RVTFabExchange.DispalyGraphicsElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6405, name: , text: Clear Graphics Selection, class: RVTFabExchange.ClearGraphicsElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6406, name: , text: Project Origin, class: RVTFabExchange.SelectCoordsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6407, name: , text: Shared Coordinates, class: RVTFabExchange.SelectCoordsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6408, name: , text: Out, class: RVTFabExchange.ExportCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Starting External Application: RME to FAB Export, Class: RVTFabExchange.Application, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6409, name: , text: Batch Print, class: Revit.PrintHarness.PrintHarnessAPI, assembly: C:\Program Files\Autodesk\Batch Print for Revit 2018\BatchPrint.dll }
' 0:< API_SUCCESS { Starting External Application: Batch Print Application, Class: Revit.PrintHarness.PrintHarnessApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Batch Print for Revit 2018\BatchPrint.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering WorksharedOperationProgressChanged event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentOpening event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering LinkedResourceOpening event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering LinkedResourceOpened event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Starting External Application: Collaborate, Class: Autodesk.Revit.UI.Collaborate.CollaborateApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' Executed implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command BIM 360 Projects Executed event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' CanExecute implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command BIM 360 Projects CanExecute event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< ::0:: Delta VM: Avail -3 -> 134216002 MB, Used +1 -> 301 MB, Peak +2 -> 302 MB; RAM: Avail +11 -> 59651 MB, Used -10 -> 448 MB, Peak +2 -> 460 MB
' 0:< API_SUCCESS { Starting External Application: CollaborateBrowser, Class: Autodesk.Revit.UI.CollaborateBrowser.CollaborateBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateBrowser.dll }
'C 06-Jul-2017 10:27:39.154; 0:< SkyscraperClientHost: UpiConfig: C:\Program Files\Autodesk\Collaboration for Revit 2018\UPI\upiconfig.xml
'C 06-Jul-2017 10:27:39.201; 0:< SkyscraperClientHost: Initialize Success: True
' 0:< API_SUCCESS { Starting External Application: SkyscraperClientHostApplication, Class: SkyscraperClientHost.SkyscraperClientHostApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\SkyscraperClientHost.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6410, name: , text: Transmit a model, class: eTransmitForRevit.eTransmitCommand, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6411, name: , text: Help, class: eTransmitForRevit.eTransmitHelp, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6412, name: , text: About, class: eTransmitForRevit.eTransmitAbout, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Starting External Application: eTransmit for Revit, Class: eTransmitForRevit.eTransmitApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6413, name: , text: Check, class: BIMStandardsManager.Command, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6414, name: , text: Manage, class: BIMStandardsManager.CommandConfig, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6415, name: , text: View, class: BIMStandardsManager.CommandReview, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6416, name: , text: About..., class: BIMStandardsManager.CommandAbout, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Starting External Application: Model Review, Class: BIMStandardsManager.ExternalApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_ERROR { Starting External Application: Model Review Events, Class: BIMStandardsManager.CommandEventsApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< ::0:: Delta VM: Avail -36 -> 134215966 MB, Used +6 -> 308 MB, Peak +5 -> 308 MB; RAM: Avail +46 -> 59697 MB, Used +5 -> 453 MB
' 0:< GUI Resource Usage GDI: Avail 9820, Used 180, User: Used 185
' 0:< API_SUCCESS { Starting External Application: Revit2RobotConnector, Class: Autodesk.Revit.UI.Revit2RobotConnector.Revit2RobotConnectorApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: c:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\RSA\Revit2RobotConnector\Revit2RobotConnector.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (26a4f622-eb0a-4829-a9c3-9194b77a7fe4). }
' 0:< API_SUCCESS { Starting External Application: AREXRevitStart, Class: REX.AREXRevitStart.AREXRevitStart, Vendor : ADSK(), Assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Products\Revit\AREXRevitStart.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (1aa95c7e-ebf6-4205-b465-993f7efdc2e1). }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (be4833f0-363a-4442-82f9-fc2805b4220f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< ::0:: Delta VM: Avail -36 -> 134215931 MB, Used 308 MB, Peak +1 -> 309 MB; RAM: Avail -8 -> 59690 MB, Used +1 -> 455 MB
' 0:< GUI Resource Usage GDI: Avail 9813, Used 187, User: Used 192
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Application, Class: WorkSharingLib.ExternalApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\WorkSharingLib.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6417, name: , text: Launch WSM, class: WorksharingCommand.WorksharingCommand, assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Launch App, Class: WorksharingCommand.WorksharingApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_GO_LIVE' Executed implementation with implementation from application 'Autodesk Revit Live Service' dll 'C:\Program Files\Autodesk\Revit Live\service\DataPrep.RevitAddIn.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Replacing command id 'ID_GO_LIVE' CanExecute implementation with implementation from application 'Autodesk Revit Live Service' dll 'C:\Program Files\Autodesk\Revit Live\service\DataPrep.RevitAddIn.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering ViewActivating event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Starting External Application: Autodesk Revit Live Service, Class: DataPrep.RevitAddIn.App, Vendor : ADSK(), Assembly: C:\Program Files\Autodesk\Revit Live\service\DataPrep.RevitAddIn.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' Executed implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' CanExecute implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Starting External Application: Communicator for Autodesk Revit, Class: Autodesk.Revit.SmartMonkeyPlugin.SmartMonkeyApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: Communicator\SmartMonkey.dll }
' 0:< API_SUCCESS { Registering Idling event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivating event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo
'Dynamo CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
'Dynamo BeforeExecuted event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll'. }
'Dynamo Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< Third Party Updater 'Dynamo For Revit: Sun and Shadow Settings Updater' registered for all documents.
' 0:< API_SUCCESS { Registering DocumentChanged event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_PLAYLIST_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo Playlist CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_PLAYLIST_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo Playlist Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Starting External Application: Dynamo For Revit, Class: Dynamo.Applications.VersionLoader, Vendor : ADSK(Dynamo), Assembly: C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' Executed implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Publish Settings Executed event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' CanExecute implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Publish Settings CanExecute event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Starting External Application: Views For A360, Class: Autodesk.Revit.Addin.ExportViewSelector.ExportViewSelectorApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: .\ExportViewSelectorAddin\ExportViewSelectorAddin.dll }
' 0:< ::0:: Delta VM: Avail -11 -> 134215921 MB, Used +1 -> 309 MB, Peak +1 -> 310 MB; RAM: Avail -8 -> 59682 MB, Used +1 -> 457 MB
' 0:< GUI Resource Usage GDI: Avail 9812, Used 188, User: Used 193
' 0:< API_SUCCESS { Added pushbutton Id: 6418, name: , text: Convert RFA
'to FormIt, class: RFAToAXMAddon.RFAToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6419, name: , text: Convert SKP
'to FormIt, class: RFAToAXMAddon.SketchUpToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6420, name: , text: Import FormIt
'to RVT, class: AXMImportorAddon.AXMImportorCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6421, name: , text: Reload Families, class: AXMImportorAddon.ReloadFamiliesCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6422, name: , text: About FormIt, class: FormItConverter.FormItLink, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\FormItConverterRibbon.dll }
' 0:< ::0:: Delta VM: Avail -5 -> 134215916 MB, Used +14 -> 324 MB, Peak +15 -> 325 MB; RAM: Avail -13 -> 59670 MB, Used +13 -> 470 MB, Peak +11 -> 471 MB
' 0:< GUI Resource Usage GDI: Avail 9810, Used 190, User: Used 194
' 0:< API_SUCCESS { Starting External Application: FormIt Conversion, Class: FormItConverter.Ribbon, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\FormItConverterRibbon.dll }
' 0:< ::0:: Delta VM: Avail -21 -> 134215895 MB, Used +4 -> 328 MB, Peak +9 -> 335 MB; RAM: Avail -4 -> 59667 MB, Used +3 -> 473 MB, Peak +1 -> 473 MB
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_NAVISWORKS' Executed implementation with implementation from application 'File exporter for Navisworks 2018' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application File exporter for Navisworks 2018 (280bb447-f630-48b0-99be-6a776ac7b5c8). }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_NAVISWORKS' CanExecute implementation with implementation from application 'File exporter for Navisworks 2018' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application File exporter for Navisworks 2018 (280bb447-f630-48b0-99be-6a776ac7b5c8). }
' 0:< API_SUCCESS { Registered an external server: Name(Navisworks 2018); VendorId(Autodesk Navisworks); ServerId(68e1934c-ec3b-410c-8c82-434f0cf25446); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Starting External Application: File exporter for Navisworks 2018, Class: NavisWorks15.LcRevitExportApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll }
'C 06-Jul-2017 10:27:40.217; 0:< ->processShellCommand
'E 06-Jul-2017 10:27:40.217; 0:<
Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -19 -> 134215877 MB, Used +6 -> 335 MB; RAM: Avail -12 -> 59655 MB, Used +12 -> 486 MB, Peak +12 -> 486 MB
' 0:< GUI Resource Usage GDI: Avail 9799, Used 201, User: Used 204
'C 06-Jul-2017 10:27:40.389; 0:< <-processShellCommand
'C 06-Jul-2017 10:27:40.389; 0:< ->DesktopMFCApp::doStartupWarnings
'C 06-Jul-2017 10:27:40.389; 0:< License readyForUI
'C 06-Jul-2017 10:27:40.435; 0:< manage debug modes
'C 06-Jul-2017 10:27:40.435; 0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< START CanUseHardware(forced)
' 1:<
'OGS Device Memory Size: 40857 MB
' 1:< ::1:: Delta VM: Avail -32963 -> 134182914 MB, Used +54 -> 390 MB, Peak +56 -> 391 MB; RAM: Avail -9 -> 59646 MB, Used +23 -> 510 MB, Peak +25 -> 511 MB
' 1:< GUI Resource Usage GDI: Avail 9798, Used 202, User: Used 217
' 1:< DX Device: DirectX 11, Hardware
' 1:< DX Device: DirectX 11, WARP
'C 06-Jul-2017 10:27:40.854; 1:< START video card certification
' 1:< ::1:: Delta VM: Avail -19 -> 134182896 MB, Used +3 -> 393 MB, Peak +3 -> 395 MB; RAM: Avail -2 -> 59645 MB, Used +2 -> 512 MB, Peak +4 -> 516 MB
' 1:<
'Current driver version: \Windows\System32\DriverStore\FileRepository\nvcvwu.inf_amd64_398c0a0c4281e441\nvldumdx.dll,C:\Windows\System32\DriverStore\F:22.21.13.8178
'Certified driver(s):
' 1:< VIDEO CARD ENVIRONMENT: CARD="NVIDIA GeForce GTX 1080" ManufacturerID="10DE" DeviceID="1BE0" osID="8000" DRIVER="\Windows\System32\DriverStore\FileRepository\nvcvwu.inf_amd64_398c0a0c4281e441\nvldumdx.dll,C:\Windows\System32\DriverStore\F:22.21.13.8178" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 06-Jul-2017 10:27:40.871; 1:< FINISH video card certification
' 0.431409 1:<<' 0:<
'Can use hardware=y
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=n
'DrvNewerThanTested=n
'CardIsNotListed=y
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 06-Jul-2017 10:27:40.871; 0:< MFCApp::testMSAA
'C 06-Jul-2017 10:27:40.871; 0:< postConditionalWarnings
'C 06-Jul-2017 10:27:40.871; 0:< giveAtomRegistrationWarnings
'C 06-Jul-2017 10:27:40.871; 0:< warnings->consumeAll
'C 06-Jul-2017 10:27:40.871; 0:< Process result of DebugModes-Changed Task Dialog
'C 06-Jul-2017 10:27:40.871; 0:< isMaterialLibraryAvailable
'C 06-Jul-2017 10:27:40.871; 0:< start up warnings for AddIns
'C 06-Jul-2017 10:27:40.872; 0:< <-DesktopMFCApp::doStartupWarnings
'C 06-Jul-2017 10:27:40.873; 0:< <-desktop InitNativeInstance
'C 06-Jul-2017 10:27:40.873; 0:< ->desktop InitManagedInstance
' 1:< API_SUCCESS { Registered an external server: Name(Site Linker); VendorId(ADSK); ServerId(c6c190c2-458e-48ea-ba79-722f26a87b45); ServiceId(c9979a42-11ab-4c25-93e1-abfb50b7be60) }
' 1:< ::1:: Delta VM: Avail -10 -> 134182887 MB, Used +3 -> 396 MB, Peak +2 -> 397 MB; RAM: Avail -20 -> 59626 MB, Used +9 -> 522 MB, Peak +7 -> 523 MB
' 1:< GUI Resource Usage GDI: Avail 9672, Used 328, User: Used 217
' 1:< API_SUCCESS { Added pushbutton Id: 6423, name: , text: Modify, class: REX.AREXRevitMngr.Modifier, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6424, name: , text: Delete, class: REX.AREXRevitMngr.Remover, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6425, name: , text: Preferences, class: REX.AREXRevitMngr.Preferences, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6426, name: , text: Frame Generator, class: REX.DLTFrame3D.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\DLTFrame3D\DLTFrame3D.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6427, name: , text: Grids Generator, class: REX.DRevitGridGenerator.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\DRevitGridGenerator\DRevitGridGenerator.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6428, name: , text: Rafter Framing, class: REX.DRafterFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\DRafterFraming\DRafterFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6429, name: , text: Roof Trusses, class: REX.DRoofTrusses.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\DRoofTrusses\DRoofTrusses.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6430, name: , text: Wood Framing Walls, class: REX.ATimberFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\ATimberFraming\ATimberFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6431, name: , text: Automatic Reinforcement Generation, class: REX.DReinfAuto.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfAuto\DReinfAuto.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6432, name: , text: Beams, class: REX.DReinfBeam.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfBeam\DReinfBeam.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6433, name: , text: Columns, class: REX.DReinfColumn.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfColumn\DReinfColumn.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6434, name: , text: Continuous Footings, class: REX.DReinfFootingCont.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfFootingCont\DReinfFootingCont.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6435, name: , text: Interferences of Reinforcing Bars, class: REX.DReinfRebarCollisions.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfRebarCollisions\DReinfRebarCollisions.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6436, name: , text: Parapets, class: REX.DReinfParapet.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfParapet\DReinfParapet.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6437, name: , text: Pile Caps, class: REX.DReinfPileCap.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfPileCap\DReinfPileCap.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6438, name: , text: Piles, class: REX.DReinfPile.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfPile\DReinfPile.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6439, name: , text: Retaining Walls, class: REX.DReinfRetainingWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfRetainingWall\DReinfRetainingWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6440, name: , text: Slab Corners, class: REX.DReinfSlabCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfSlabCorner\DReinfSlabCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6441, name: , text: Slab Openings, class: REX.DReinfSlabOpening.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfSlabOpening\DReinfSlabOpening.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6442, name: , text: Spread Footings, class: REX.DReinfFootingSpread.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfFootingSpread\DReinfFootingSpread.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6443, name: , text: Wall Corners, class: REX.DReinfWallCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfWallCorner\DReinfWallCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6444, name: , text: Walls, class: REX.DReinfWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfWall\DReinfWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6445, name: , text: Compare Models, class: REX.DRevitModelsCompare.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Tools\DRevitModelsCompare\DRevitModelsCompare.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6446, name: , text: Element Positioning, class: REX.DElementsPositioning.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Tools\DElementsPositioning\DElementsPositioning.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6447, name: , text: Reinforcement Code Check, class: REX.DReinfDesign.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\RSA\DReinfDesign\DReinfDesign.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6448, name: , text: Robot Structural Analysis Link, class: REX.DRevit2Robot.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\RSA\DRevit2Robot\DRevit2Robot.dll }
' 1:< ::1:: Delta VM: Avail -12 -> 134182875 MB, Used +1 -> 397 MB; RAM: Avail -7 -> 59619 MB, Used +2 -> 525 MB, Peak +2 -> 525 MB
' 1:< GUI Resource Usage GDI: Avail 9664, Used 336, User: Used 217
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfBeam' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfColumn' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfFootingSpread' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfWall' registered for all documents.
' 1:< API_SUCCESS { Registering DocumentOpened event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DocumentCreated event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DisplayingOptionsDialog event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering ViewActivated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
'C 06-Jul-2017 10:27:42.891; 0:< <-desktop InitManagedInstance
' 0:< ::1:: Delta VM: Avail -40 -> 134182836 MB, Used +5 -> 403 MB, Peak +5 -> 403 MB; RAM: Avail -24 -> 59596 MB, Used +23 -> 548 MB, Peak +23 -> 548 MB
' 0:< GUI Resource Usage GDI: Avail 9635, Used 365, User: Used 221
'C 06-Jul-2017 10:27:43.116; 0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:< BuildNumber : 14393
' 0:< BuildType : Multiprocessor Free
' 0:< Caption : Microsoft Windows 10 Pro
' 0:< CodeSet : 1252
' 0:< CountryCode : 1
' 0:< FreePhysicalMemory : 61024004
' 0:< FreeSpaceInPagingFiles : 9961472
' 0:< FreeVirtualMemory : 70843724
' 0:< MaxProcessMemorySize : 137438953344
' 0:< OSLanguage : 1033
' 0:< OSType : 18
' 0:< ServicePackMajorVersion : 0
' 0:< ServicePackMinorVersion : 0
' 0:< TotalVirtualMemorySize : 77026692
' 0:< TotalVisibleMemorySize : 67065220
' 0:< Version : 10.0.14393
' 0:< ::1:: Delta VM: Avail -11 -> 134182826 MB, Used +1 -> 405 MB, Peak +2 -> 405 MB; RAM: Avail -10 -> 59587 MB, Used +2 -> 551 MB, Peak +3 -> 551 MB
' 0:< GUI Resource Usage GDI: Avail 9635, Used 365, User: Used 229
' 0:< Process affinity mask : FF
' 0:< System affinity mask : FF
' 0:< ::1:: Delta VM: Avail 134182826 MB, Used 405 MB, Peak +1 -> 406 MB; RAM: Avail +14 -> 59602 MB, Used 551 MB, Peak +0 -> 552 MB
' 0:< GUI Resource Usage GDI: Avail 9635, Used 365, User: Used 228
' 0:< PROCESSOR INFORMATION:
' 0:< AddressWidth : 64
' 0:< Architecture : 9
' 0:< Availability : 3
' 0:< Caption : Intel64 Family 6 Model 94 Stepping 3
' 0:< CurrentClockSpeed : 4001
' 0:< DataWidth : 64
' 0:< Description : Intel64 Family 6 Model 94 Stepping 3
' 0:< Family : 198
' 0:< L2CacheSize : 1024
' 0:< Level : 6
' 0:< Manufacturer : GenuineIntel
' 0:< MaxClockSpeed : 4001
' 0:< Name : Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
' 0:< ProcessorType : 3
' 0:< Revision : 24067
' 0:< Role : CPU
' 0:< SocketDesignation : U3E1
' 0:< StatusInfo : 3
' 0:< Version :
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:< AdapterCompatibility : NVIDIA
' 0:< AdapterDACType : Integrated RAMDAC
' 0:< AdapterRAM : -1048576
' 0:< Caption : NVIDIA GeForce GTX 1080
' 0:< CurrentBitsPerPixel : 32
' 0:< CurrentHorizontalResolution : 1920
' 0:< CurrentNumberOfColors : 4294967296
' 0:< CurrentRefreshRate : 75
' 0:< CurrentVerticalResolution : 1080
' 0:< Description : NVIDIA GeForce GTX 1080
' 0:< DriverDate : 20170412000000.000000-000
' 0:< DriverVersion : 22.21.13.8178
' 0:< MaxRefreshRate : 75
' 0:< MinRefreshRate : 75
' 0:< Monochrome : 0
' 0:< Name : NVIDIA GeForce GTX 1080
' 0:< VideoArchitecture : 5
' 0:< VideoMemoryType : 2
' 0:< VideoModeDescription : 1920 x 1080 x 4294967296 colors
' 0:< VideoProcessor : GeForce GTX 1080
' 0:< ::1:: Delta VM: Avail 134182826 MB, Used 405 MB; RAM: Avail -40 -> 59562 MB, Used +0 -> 552 MB, Peak +0 -> 553 MB
'E 06-Jul-2017 10:27:46.254; 0:<
Jrn.AppButtonEvent 1 , "Application Menu is opening"
' 0:< ::2:: Delta VM: Avail -3 -> 134182824 MB, Used +1 -> 406 MB, Peak +0 -> 407 MB; RAM: Avail -31 -> 59531 MB, Used +4 -> 557 MB, Peak +4 -> 557 MB
' 0:< GUI Resource Usage GDI: Avail 9627, Used 373, User: Used 236
' 0:< PRINTER INFORMATION:
' 0:< Caption : Send To OneNote 2016
' 0:< Default : 0
' 0:< DeviceID : Send To OneNote 2016
' 0:< Direct : 0
' 0:< DriverName : Send to Microsoft OneNote 16 Driver
' 0:< EnableBIDI : 0
' 0:< EnableDevQueryPrint : 0
' 0:< HorizontalResolution : 600
' 0:< Local : -1
' 0:< Name : Send To OneNote 2016
' 0:< Network : 0
' 0:< PortName : nul:
' 0:< PrintJobDataType : RAW
' 0:< PrintProcessor : winprint
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< SpoolEnabled : -1
' 0:< VerticalResolution : 600
' 0:< Caption : NPIC5A415 (HP PageWide XL 5000PS MFP)
' 0:< Default : 0
' 0:< DeviceID : NPIC5A415 (HP PageWide XL 5000PS MFP)
' 0:< Direct : 0
' 0:< DriverName : HP Designjet T Series PS Class Driver
' 0:< Local : -1
' 0:< Name : NPIC5A415 (HP PageWide XL 5000PS MFP)
' 0:< Network : 0
' 0:< PortName : WSD-a4734973-8636-45cc-87ee-e6993dde7623.0035
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft XPS Document Writer
' 0:< Default : 0
' 0:< DeviceID : Microsoft XPS Document Writer
' 0:< Direct : 0
' 0:< DriverName : Microsoft XPS Document Writer v4
' 0:< Local : -1
' 0:< Name : Microsoft XPS Document Writer
' 0:< Network : 0
' 0:< PortName : PORTPROMPT:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft Print to PDF
' 0:< Default : 0
' 0:< DeviceID : Microsoft Print to PDF
' 0:< Direct : 0
' 0:< DriverName : Microsoft Print To PDF
' 0:< Local : -1
' 0:< Name : Microsoft Print to PDF
' 0:< Network : 0
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Fax
' 0:< Default : 0
' 0:< DeviceID : Fax
' 0:< Direct : 0
' 0:< DriverName : Microsoft Shared Fax Driver
' 0:< HorizontalResolution : 200
' 0:< Local : -1
' 0:< Name : Fax
' 0:< Network : 0
' 0:< PortName : SHRFAX:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 200
' 0:< Caption : Bluebeam PDF
' 0:< Default : -1
' 0:< DeviceID : Bluebeam PDF
' 0:< Direct : 0
' 0:< DriverName : BluebeamPSDriver
' 0:< Local : -1
' 0:< Name : Bluebeam PDF
' 0:< Network : 0
' 0:< PortName : BLUEBEAMPDFPORT
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Adobe PDF
' 0:< Default : 0
' 0:< DeviceID : Adobe PDF
' 0:< Direct : 0
' 0:< DriverName : Adobe PDF Converter
' 0:< HorizontalResolution : 1200
' 0:< Local : -1
' 0:< Name : Adobe PDF
' 0:< Network : 0
' 0:< PortName : Documents\*.pdf
' 0:< RawOnly : -1
' 0:< Shared : 0
' 0:< VerticalResolution : 1200
' 0:< Caption : \\fs1\142 Ricoh plotter
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Ricoh plotter
' 0:< Direct : 0
' 0:< DriverName : Gestetner GWD3006 PS
' 0:< EnableBIDI : -1
' 0:< Local : 0
' 0:< Name : \\fs1\142 Ricoh plotter
' 0:< Network : -1
' 0:< PortName : 192.168.37.155
' 0:< PrintProcessor : E150PP64
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\140 Toshiba C
' 0:< Default : 0
' 0:< DeviceID : \\fs1\140 Toshiba C
' 0:< Direct : 0
' 0:< DriverName : TOSHIBA Universal Printer 2
' 0:< Local : 0
' 0:< Name : \\fs1\140 Toshiba C
' 0:< Network : -1
' 0:< PortName : 10.120.223.113_1
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 Canon ipf815 (new on right)
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Canon ipf815 (new on right)
' 0:< Direct : 0
' 0:< DriverName : Canon iPF815
' 0:< Local : 0
' 0:< Name : \\fs1\142 Canon ipf815 (new on right)
' 0:< Network : -1
' 0:< PortName : 192.168.37.249_1
' 0:< PrintProcessor : Canon iPF815 Print Processor
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 HP Pagewide 5000 PS
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 HP Pagewide 5000 PS
' 0:< Direct : 0
' 0:< DriverName : HP PageWide XL 5000PS MFP PS3
' 0:< Local : 0
' 0:< Name : \\fs1\142 HP Pagewide 5000 PS
' 0:< Network : -1
' 0:< PortName : 10.120.223.168
' 0:< PrintProcessor : hpipp151
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 Ricoh copier upstairs (stapler)
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Ricoh copier upstairs (stapler)
' 0:< Direct : 0
' 0:< DriverName : SAVIN MP 5002 PCL 6
' 0:< Local : 0
' 0:< Name : \\fs1\142 Ricoh copier upstairs (stapler)
' 0:< Network : -1
' 0:< PortName : 192.168.37.141
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 Canon ipf815 plotter
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Canon ipf815 plotter
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Name : \\fs1\142 Canon ipf815 plotter
' 0:< Network : -1
' 0:< PortName : 192.168.37.252
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\179 lincoln st Canon iPF815
' 0:< Default : 0
' 0:< DeviceID : \\fs1\179 lincoln st Canon iPF815
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Name : \\fs1\179 lincoln st Canon iPF815
' 0:< Network : -1
' 0:< PortName : 192.168.40.222
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\Oce PlotWave 365 Right
' 0:< Default : 0
' 0:< DeviceID : \\fs1\Oce PlotWave 365 Right
' 0:< Direct : 0
' 0:< DriverName : Oce PlotWave 365 PS
' 0:< Local : 0
' 0:< Name : \\fs1\Oce PlotWave 365 Right
' 0:< Network : -1
' 0:< PortName : 10.120.223.152_PW365
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\Oce PlotWave 365 Left
' 0:< Default : 0
' 0:< DeviceID : \\fs1\Oce PlotWave 365 Left
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Name : \\fs1\Oce PlotWave 365 Left
' 0:< Network : -1
' 0:< PortName : 10.120.223.153_PW365
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 11x17 color
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 11x17 color
' 0:< Direct : 0
' 0:< DriverName : Brother MFC-J6720DW Printer
' 0:< Local : 0
' 0:< Name : \\fs1\142 11x17 color
' 0:< Network : -1
' 0:< PortName : WSD-bef11bf2-7cce-4b5a-b63a-1e19dbcddc64.0034
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\HP PageWide XL 5000PS MFP HPGL2
' 0:< Default : 0
' 0:< DeviceID : \\fs1\HP PageWide XL 5000PS MFP HPGL2
' 0:< Direct : 0
' 0:< DriverName : HP PageWide XL 5000PS MFP HPGL2
' 0:< Local : 0
' 0:< Name : \\fs1\HP PageWide XL 5000PS MFP HPGL2
' 0:< Network : -1
' 0:< PrintProcessor : hpipp161
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Default : 0
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Network : -1
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 24" Canon Plotter
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 24" Canon Plotter
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Name : \\fs1\142 24" Canon Plotter
' 0:< Network : -1
' 0:< PortName : 192.168.37.174
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 Canon copier downstairs
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Canon copier downstairs
' 0:< Direct : 0
' 0:< DriverName : Canon iR-ADV 4225/4235 PCL5e
' 0:< Local : 0
' 0:< Name : \\fs1\142 Canon copier downstairs
' 0:< Network : -1
' 0:< PortName : 192.168.37.250_2
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Send To OneNote 2016
' 0:< DriverVersion : 1539
' 0:< Orientation : 1
' 0:< PaperLength : 2794
' 0:< PaperSize : Letter 8 1/2 x 11 in
' 0:< PaperWidth : 2159
' 0:< PrintQuality : 600
' 0:< SpecificationVersion : 1025
' 0:< XResolution : 600
' 0:< YResolution : 600
' 0:< Copies : 1
' 0:< Description : NPIC5A415 (HP PageWide XL 5000PS MFP)
' 0:< MediaType : 256
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft XPS Document Writer
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft Print to PDF
' 0:< Color : 1
' 0:< Description : Fax
' 0:< DriverVersion : 1024
' 0:< Duplex : 0
' 0:< PrintQuality : 200
' 0:< XResolution : 200
' 0:< YResolution : 200
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Bluebeam PDF
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Adobe PDF
' 0:< PrintQuality : 1200
' 0:< XResolution : 1200
' 0:< YResolution : 1200
' 0:< Description : \\fs1\142 Ricoh plotter
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\fs1\140 Toshiba C
' 0:< Duplex : 0
' 0:< Description : \\fs1\142 Canon ipf815 (new on right)
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\fs1\142 HP Pagewide 5000 PS
' 0:< MediaType : 1
' 0:< Orientation : 2
' 0:< Description : \\fs1\142 Ricoh copier upstairs (stapler)
' 0:< Description : \\fs1\142 Canon ipf815 plotter
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\fs1\179 lincoln st Canon iPF815
' 0:< DriverVersion : 1067
' 0:< Description : \\fs1\Oce PlotWave 365 Right
' 0:< Description : \\fs1\Oce PlotWave 365 Left
' 0:< Description : \\fs1\142 11x17 color
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\fs1\HP PageWide XL 5000PS MFP HPGL2
' 0:< MediaType : 1
' 0:< Color : 2
' 0:< Copies : 1
' 0:< MediaType : 1
' 0:< Description : \\fs1\142 24" Canon Plotter
' 0:< Copies : 1
' 0:< Description : \\fs1\142 Canon copier downstairs
' 0:< DriverVersion : 5381
' 0:< Duplex : -1
' 0:< ::2:: Delta VM: Avail 134182824 MB, Used 406 MB; RAM: Avail -14 -> 59518 MB, Used 557 MB
' 0:< GUI Resource Usage GDI: Avail 9627, Used 373, User: Used 237
'E 06-Jul-2017 10:27:47.182; 0:<
Jrn.AppButtonEvent 0 , "Application Menu is closing"
'E 06-Jul-2017 10:27:47.208; 0:<
Jrn.Command "Ribbon" , "Open an existing project , ID_REVIT_FILE_OPEN"
Message 17 of 21
jelwell3QWFZ
' 0:< Initial VM: Avail 134217376 MB, Used 16 MB, Peak 16; RAM: Avail 60252 MB, Used 56 MB, Peak 16
' 0:< GUI Resource Usage GDI: Avail 9995, Used 5, User: Used 3
'C 06-Jul-2017 10:27:28.198; 0:< started recording journal file
' Build: 20170223_1515(x64)
' Branch: RELEASE_2018_SHIP
Dim Jrn
Set Jrn = CrsJournalScript
'C 06-Jul-2017 10:27:28.198; 0:< ->desktop InitApplication
'C 06-Jul-2017 10:27:28.198; 0:< <-desktop InitApplication
'C 06-Jul-2017 10:27:28.198; 0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2018\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2018\Libraries\US Imperial\Detail Items (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -24 -> 134217352 MB, Used +4 -> 21 MB, Peak +4 -> 21 MB; RAM: Avail -65 -> 60188 MB, Used +11 -> 68 MB, Peak +11 -> 68 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 28
'C 06-Jul-2017 10:27:28.964; 0:< License initialization complete
' 0:< License version: 18.5.4.1
' 0:< ::0:: Delta VM: Avail -180 -> 134217173 MB, Used +31 -> 52 MB, Peak +33 -> 55 MB; RAM: Avail -66 -> 60122 MB, Used +49 -> 117 MB, Peak +49 -> 117 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 52
' 0:< SystemSettings:
' 0:< 8=multiCoreCharacteristic
' 0:< true=isDotNetInstalled
' 0:< 4.6.01586(394802)=dotNetInstalledVersionString
' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -21 -> 134217152 MB, Used +8 -> 60 MB, Peak +5 -> 60 MB; RAM: Avail -14 -> 60108 MB, Used +16 -> 133 MB, Peak +16 -> 133 MB
' 0:< GUI Resource Usage GDI: Avail 9970, Used 30, User: Used 66
'C 06-Jul-2017 10:27:29.280; 0:< manage licensing
' 0:< ::0:: Delta VM: Avail -49 -> 134217103 MB, Used +5 -> 66 MB, Peak +14 -> 75 MB; RAM: Avail -6 -> 60103 MB, Used +14 -> 147 MB, Peak +20 -> 154 MB
' 0:< GUI Resource Usage GDI: Avail 9970, Used 30, User: Used 69
' 0:< License mode: Standalone
' 0:< Status: Your license is non-expiring.
' 0:< Type: Standalone - Locked
' 0:< Usage: Commercial
' 0:< Behavior: Permanent
' 0:< Expiration: None
'C 06-Jul-2017 10:27:31.105; 0:< manage involvement
' 0:< ::0:: Delta VM: Avail -632 -> 134216471 MB, Used +45 -> 112 MB, Peak +37 -> 112 MB; RAM: Avail -36 -> 60067 MB, Used +51 -> 198 MB, Peak +44 -> 198 MB
' 0:< GUI Resource Usage GDI: Avail 9935, Used 65, User: Used 105
' 0:< Setting WPF rendering mode to SoftwareOnly
' 0:< ::0:: Delta VM: Avail -125 -> 134216347 MB, Used +67 -> 180 MB, Peak +67 -> 180 MB; RAM: Avail -88 -> 59980 MB, Used +87 -> 286 MB, Peak +87 -> 286 MB
' 0:< GUI Resource Usage GDI: Avail 9829, Used 171, User: Used 178
' 0:< Autodesk Revit 2018
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2018
' 0:< this journal = C:\Users\jelwell\AppData\Local\Autodesk\Revit\Autodesk Revit 2018\Journals\journal.0054.txt
' 0:< Journal Init
'C 06-Jul-2017 10:27:34.480; 0:< Log Summary
' 0:< .Count
' 0:< ...PendingMessages = 32
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 51
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 8
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
' 0:< BC: 0,0,0
'H 06-Jul-2017 10:27:34.480; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Construction Template=$AllUsersAppData\Templates\US Imperial\Construction-Default.rte, Architectural Template=$AllUsersAppData\Templates\US Imperial\default.rte, Structural Template=$AllUsersAppData\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=$AllUsersAppData\Templates\US Imperial\Mechanical-Default.rte"
Jrn.Data "JournalDefaultViewDiscipline" _
, "Coordination"
Jrn.Directive "Version" _
, "2018.000", "2.154"
Jrn.Directive "Username" _
, "JElwell"
Jrn.Directive "CategoryDisciplineFilter" _
, -1
Jrn.Directive "DisciplineOption" _
, 7677
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
Jrn.Directive "AllowLinkSelection" _
, 1
Jrn.Directive "AllowFaceSelection" _
, 0
Jrn.Directive "AllowUnderlaySelection" _
, 0
Jrn.Directive "AllowPinnedSelection" _
, 1
Jrn.Directive "ThinLinesEnabled" _
, 0
'C 06-Jul-2017 10:27:34.496; 1:< logging master created MasterQueue Session10436_P0MasterQueue
'C 06-Jul-2017 10:27:34.496; 1:< logging started queue minder
'C 06-Jul-2017 10:27:34.496; 1:< logging started worker services
' 0:< ::0:: Delta VM: Avail -57 -> 134216291 MB, Used +27 -> 207 MB, Peak +28 -> 208 MB; RAM: Avail -88 -> 59892 MB, Used +31 -> 317 MB, Peak +33 -> 319 MB
' 0:< GUI Resource Usage GDI: Avail 9828, Used 172, User: Used 178
' 0:< API_SUCCESS { Registered an external service: Name(DirectContext3D Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(SteelConnectionsService); VendorId(ADSK); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Site Insert Service); VendorId(ADSK); ServiceId(c9979a42-11ab-4c25-93e1-abfb50b7be60) }
' 0:< API_SUCCESS { Registered an external service: Name(RebarUpdateService); VendorId(ADSK); ServiceId(a2c22b44-c231-4d3f-b653-b81b6f8be150) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource UI Service); VendorId(ADSK); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Registered an external service: Name(Point Cloud Snapping Service); VendorId(ADSK); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< ::0:: Delta VM: Avail +0 -> 134216292 MB, Used +5 -> 213 MB, Peak +13 -> 222 MB; RAM: Avail -63 -> 59830 MB, Used +15 -> 333 MB, Peak +22 -> 341 MB
' 0:< GUI Resource Usage GDI: Avail 9828, Used 172, User: Used 180
' 0:< API_SUCCESS { Added pushbutton 35011, name Navisworks 2018, class NavisWorks15.LcRevitExportCommand, vendorId ADSK (Autodesk, www.autodesk.com), assembly ./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll }
' 0:< API_SUCCESS { Added pushbutton 35012, name Navisworks SwitchBack 2018, class NavisWorks15.LcActivateSwitchBack, vendorId ADSK (Autodesk, www.autodesk.com), assembly ./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll }
' 0:< ::0:: Delta VM: Avail -246 -> 134216047 MB, Used +68 -> 281 MB, Peak +59 -> 281 MB; RAM: Avail -144 -> 59686 MB, Used +91 -> 424 MB, Peak +83 -> 424 MB
' 0:< To make IFC server work.
' 0:< API_SUCCESS { Registered an external server: Name(Autodesk Drive); VendorId(ADSK); ServerId(baddc547-d952-4d29-ae01-16e71e75aa63); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: ConnectedDesktopDB, Class: ConnectedDesktopDB.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\ConnectedDesktop\ConnectedDesktopDB.dll }
' 0:< Third Party Updater 'CoordinationModelDB: CoordinationModelDBUpdater' registered for all documents.
' 0:< API_SUCCESS { Registering DocumentOpened event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Starting External DB Application: CoordinationModelDB, Class: Autodesk.CoordinationModelDB.CoordinationModelDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\CoordinationModel\CoordinationModelDB.dll }
' 0:< ::0:: Delta VM: Avail -2 -> 134216045 MB, Used +0 -> 282 MB, Peak +2 -> 284 MB; RAM: Avail -11 -> 59676 MB, Used +4 -> 429 MB, Peak +5 -> 430 MB
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default DB Server); VendorId(ADSK); ServerId(bd4f0f53-394a-4468-b37e-1e7949013382); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: KeynoteDBServer, Class: KeynoteDBServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\Keynote\KeynoteDBServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Plumbing Fixture Flow); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshul-Tsal Equation); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Starting External DB Application: StraightSegmentCalculationServersApp, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\StraightSegmentCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Coefficient from ASHRAE Table); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(K Coefficient from Table); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: FittingAndAccessoryCalculationServers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\FittingAndAccessoryCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SteelConnectionsServer); VendorId(ADSK); ServerId(9c209d4a-ec98-460f-bfde-38f17a3443b4); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external server: Name(FramingProfileServer); VendorId(ADSK); ServerId(54e490cd-8809-4dbb-84dd-dc0bc6cb1712); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Starting External DB Application: ExternalResourceDBServer, Class: RvtSteelConnectionsDB.SteelConnectionDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\SteelConnections\RvtSteelConnectionsDB.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Site Linker Utility Application (01673995-d4d5-4c62-a184-98e970ef7805). }
' 0:< API_SUCCESS { Registering PositionsSaved event by application Site Linker Utility Application (01673995-d4d5-4c62-a184-98e970ef7805). }
' 0:< API_SUCCESS { Starting External DB Application: Site Linker Utility Application, Class: SiteLinker.SiteServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\SiteLinker\SiteLinker.dll }
' 0:< ::0:: Delta VM: Avail -5 -> 134216040 MB, Used +3 -> 286 MB, Peak +2 -> 286 MB; RAM: Avail -12 -> 59665 MB, Used +7 -> 437 MB, Peak +6 -> 437 MB
'C 06-Jul-2017 10:27:37.864; 0:< Journal Logger Registered with Application Services, from within CollaborateDB Addon
' 0:< API_SUCCESS { Registering DocumentOpening event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Starting External DB Application: CollaborateDB, Class: Autodesk.Revit.UI.Collaborate.CollaborateDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateDB.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 134216014 MB, Used +9 -> 295 MB, Peak +9 -> 296 MB; RAM: Avail -19 -> 59646 MB, Used +14 -> 451 MB, Peak +15 -> 452 MB
' 0:< GUI Resource Usage GDI: Avail 9828, Used 172, User: Used 184
' 0:< API_SUCCESS { Registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Starting External Application: RaaS, Class: Autodesk.RaaS.RevitAddin.EApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: RaaSApplication.dll }
'H 06-Jul-2017 10:27:38.263; 0:<
Jrn.Directive "IdleTimeTaskSymbol" _
, "0.ExternalEvent"
' 0:< API_SUCCESS { Starting External Application: AutoLoad, Class: AutoLoader.AutoLoader, Vendor : ADSK(), Assembly: AutoLoader.dll }
' 0:< API_SUCCESS { Registered an external server: Name(AutodeskDriveUI); VendorId(ADSK); ServerId(314de911-0991-4787-a0fd-914be9138034); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: ConnectedDesktopUI, Class: ConnectedDesktopUI.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ConnectedDesktopUI.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COORDINATION_MODEL' Executed implementation with implementation from application 'CoordinationModelUI' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\CoordinationModel\CoordinationModelUI.dll'. }
' 0:< API_SUCCESS { API registering command Coordination Model Executed event by application CoordinationModelUI (9817e4a5-0333-4323-b69e-781db5f70005). }
' 0:< API_SUCCESS { Replacing command id 'ID_COORDINATION_MODEL' CanExecute implementation with implementation from application 'CoordinationModelUI' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\CoordinationModel\CoordinationModelUI.dll'. }
' 0:< API_SUCCESS { API registering command Coordination Model CanExecute event by application CoordinationModelUI (9817e4a5-0333-4323-b69e-781db5f70005). }
' 0:< API_SUCCESS { Starting External Application: CoordinationModelUI, Class: Autodesk.CoordinationModelUI.CoordinationModelUIApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: CoordinationModelUI.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_CEA_OPTIMIZE' Executed implementation with implementation from application 'Energy Analysis' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\EnergyAnalysis\EnergyAnalysis.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Energy Analysis (f50a2212-f174-4890-84a9-064c3c835c4d). }
' 0:< API_SUCCESS { Replacing command id 'ID_CEA_OPTIMIZE' CanExecute implementation with implementation from application 'Energy Analysis' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\EnergyAnalysis\EnergyAnalysis.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Energy Analysis (f50a2212-f174-4890-84a9-064c3c835c4d). }
' 0:< API_SUCCESS { Starting External Application: Energy Analysis, Class: EnergyAnalysis.Application, Vendor : ADSK(), Assembly: EnergyAnalysis.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
'H 06-Jul-2017 10:27:38.482; 0:<
, "1.OnIdleTask"
' 0:< API_SUCCESS { Registering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering FabricationPartBrowserChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Show Service in Part Browser
'Show Service in Part Browser
'Show Service in Part Browser CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Starting External Application: FabPartBrowserApplication, Class: FabricationPartBrowser.FabPartBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FabricationPartBrowser.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Duct not defined pressure drop UI server); VendorId(ADSK); ServerId(607992d7-359d-4593-b497-8aa238e2c564); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(9641a039-441e-42e2-93a6-c0e2177cc23c); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific loss pressure drop UI server); VendorId(ADSK); ServerId(d3b5e81d-9b8c-40da-8efb-99dd37fda611); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(25fa8de2-67c4-47d1-91f6-bd6f0803a5ed); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe not defined pressure drop UI server); VendorId(ADSK); ServerId(62917391-e14d-4897-ad0c-05342d71e4f9); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(247265b6-7b71-4147-97c6-cc52b39c12aa); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific loss pressure drop UI server); VendorId(ADSK); ServerId(5978b92a-3f0b-4691-bbc8-caf2fae20a71); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe K coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(cda19b6f-fbd5-4725-a0ce-f159bf5d02fe); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Starting External Application: FittingAndAccessoryCalculationUIServers, Class: FittingAndAccessoryCalculationUIServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FittingAndAccessoryCalculationUIServers.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_IFC' Executed implementation with implementation from application 'IFC override' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\IFCExporterUI\IFCExportUI.dll'. }
' 0:< API_SUCCESS { API registering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< API_SUCCESS { Starting External Application: IFC override, Class: BIM.IFC.Export.UI.IFCCommandOverrideApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: IFCExportUI.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default UI Server.); VendorId(ADSK); ServerId(3ffc688a-bb2e-4145-90ab-9443da02aef6); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: KeynoteUIServer, Class: KeynoteUIServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: KeynoteUIServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Internal Forces Server); VendorId(ADSK); ServerId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Starting External Application: Member Forces, Class: MemberForcesUI.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: MemberForces.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' Executed implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' CanExecute implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Starting External Application: Object Numbering, Class: BIM.Numbering.UI.NumberingUIApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ObjectNumberingUI.dll }
' 0:< API_SUCCESS { Registered an external server: Name(PointCloudSnappingServer); VendorId(ADSK); ServerId(85f4b666-8811-4e3d-9ed4-3d2ae4cd2e4c); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< Third Party Updater 'PointCloudSnappingServer: Snapping Pipe Updater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: PointCloudSnappingServer, Class: PointCloudSnappingServer.Application, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PointCloudSnappingServer.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Starting External Application: PressureLossReport, Class: PressureLossReport.PressureLossReportApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PressureLossReport.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Surface Distribution Server); VendorId(ADSK); ServerId(26046cb6-7954-47a3-ab4f-ee3a7e35a2ec); ServiceId(a2c22b44-c231-4d3f-b653-b81b6f8be150) }
' 0:< API_SUCCESS { Starting External Application: RebarUpdateApp, Class: RebarMorphedServer.RebarUpdateApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: RebarMorphedServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SectionTypeParameterServer); VendorId(ADSK); ServerId(1b91ce46-ddb4-44ec-a942-d45efadde353); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Starting External Application: Structural Section Properties, Class: SectionProperties.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SectionProperties.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_FILE_TOPOSURFACE_CONVERT_TO_LINK' Executed implementation with implementation from application 'Site Linker Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SiteLinker\SiteLinker.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Site Linker Application (26af0fb8-0ceb-46dc-a0b1-79e0208edcdc). }
' 0:< API_SUCCESS { Replacing command id 'ID_FILE_TOPOSURFACE_CONVERT_TO_LINK' CanExecute implementation with implementation from application 'Site Linker Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SiteLinker\SiteLinker.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Site Linker Application (26af0fb8-0ceb-46dc-a0b1-79e0208edcdc). }
' 0:< API_SUCCESS { Starting External Application: Site Linker Application, Class: SiteLinker.SiteExportApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SiteLinker.dll }
' 0:< ::0:: Delta VM: Avail -11 -> 134216004 MB, Used +4 -> 299 MB, Peak +3 -> 299 MB; RAM: Avail -7 -> 59640 MB, Used +5 -> 457 MB, Peak +5 -> 458 MB
' 0:< GUI Resource Usage GDI: Avail 9824, Used 176, User: Used 185
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SPACE_NAMING_UTILITY' CanExecute implementation with implementation from application 'Space Naming Utility Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SpaceNaming\SpaceNaming.dll'. }
' 0:< API_SUCCESS { API registering command Space Naming Utility CanExecute event by application Space Naming Utility Application (02663093-563b-4e2f-b5be-5b75beb2e313). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SPACE_NAMING_UTILITY' Executed implementation with implementation from application 'Space Naming Utility Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SpaceNaming\SpaceNaming.dll'. }
' 0:< API_SUCCESS { API registering command Space Naming Utility Executed event by application Space Naming Utility Application (02663093-563b-4e2f-b5be-5b75beb2e313). }
' 0:< API_SUCCESS { Starting External Application: Space Naming Utility Application, Class: SpaceNaming.Command, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SpaceNaming.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6400, name: , text: Store Design Line Elements, class: RVTFabExchange.StoreDesignLineElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6401, name: , text: Display Design Selection, class: RVTFabExchange.DispalyDesignLineElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6402, name: , text: Clear Design Selection, class: RVTFabExchange.ClearDesignLineElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6403, name: , text: Store Graphics Elements, class: RVTFabExchange.StoreGraphicsElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6404, name: , text: Display Graphics Selection, class: RVTFabExchange.DispalyGraphicsElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6405, name: , text: Clear Graphics Selection, class: RVTFabExchange.ClearGraphicsElementsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6406, name: , text: Project Origin, class: RVTFabExchange.SelectCoordsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6407, name: , text: Shared Coordinates, class: RVTFabExchange.SelectCoordsCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6408, name: , text: Out, class: RVTFabExchange.ExportCmd, assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Starting External Application: RME to FAB Export, Class: RVTFabExchange.Application, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Common Files\Autodesk Shared\Fabrication 2018\Revit 2018\RVTFabExchange64_Export.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6409, name: , text: Batch Print, class: Revit.PrintHarness.PrintHarnessAPI, assembly: C:\Program Files\Autodesk\Batch Print for Revit 2018\BatchPrint.dll }
' 0:< API_SUCCESS { Starting External Application: Batch Print Application, Class: Revit.PrintHarness.PrintHarnessApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Batch Print for Revit 2018\BatchPrint.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering WorksharedOperationProgressChanged event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentOpening event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering LinkedResourceOpening event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering LinkedResourceOpened event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Starting External Application: Collaborate, Class: Autodesk.Revit.UI.Collaborate.CollaborateApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' Executed implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command BIM 360 Projects Executed event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' CanExecute implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command BIM 360 Projects CanExecute event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< ::0:: Delta VM: Avail -3 -> 134216002 MB, Used +1 -> 301 MB, Peak +2 -> 302 MB; RAM: Avail +11 -> 59651 MB, Used -10 -> 448 MB, Peak +2 -> 460 MB
' 0:< API_SUCCESS { Starting External Application: CollaborateBrowser, Class: Autodesk.Revit.UI.CollaborateBrowser.CollaborateBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateBrowser.dll }
'C 06-Jul-2017 10:27:39.154; 0:< SkyscraperClientHost: UpiConfig: C:\Program Files\Autodesk\Collaboration for Revit 2018\UPI\upiconfig.xml
'C 06-Jul-2017 10:27:39.201; 0:< SkyscraperClientHost: Initialize Success: True
' 0:< API_SUCCESS { Starting External Application: SkyscraperClientHostApplication, Class: SkyscraperClientHost.SkyscraperClientHostApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\SkyscraperClientHost.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6410, name: , text: Transmit a model, class: eTransmitForRevit.eTransmitCommand, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6411, name: , text: Help, class: eTransmitForRevit.eTransmitHelp, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6412, name: , text: About, class: eTransmitForRevit.eTransmitAbout, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Starting External Application: eTransmit for Revit, Class: eTransmitForRevit.eTransmitApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6413, name: , text: Check, class: BIMStandardsManager.Command, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6414, name: , text: Manage, class: BIMStandardsManager.CommandConfig, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6415, name: , text: View, class: BIMStandardsManager.CommandReview, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6416, name: , text: About..., class: BIMStandardsManager.CommandAbout, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Starting External Application: Model Review, Class: BIMStandardsManager.ExternalApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_ERROR { Starting External Application: Model Review Events, Class: BIMStandardsManager.CommandEventsApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< ::0:: Delta VM: Avail -36 -> 134215966 MB, Used +6 -> 308 MB, Peak +5 -> 308 MB; RAM: Avail +46 -> 59697 MB, Used +5 -> 453 MB
' 0:< GUI Resource Usage GDI: Avail 9820, Used 180, User: Used 185
' 0:< API_SUCCESS { Starting External Application: Revit2RobotConnector, Class: Autodesk.Revit.UI.Revit2RobotConnector.Revit2RobotConnectorApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: c:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\RSA\Revit2RobotConnector\Revit2RobotConnector.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (26a4f622-eb0a-4829-a9c3-9194b77a7fe4). }
' 0:< API_SUCCESS { Starting External Application: AREXRevitStart, Class: REX.AREXRevitStart.AREXRevitStart, Vendor : ADSK(), Assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Products\Revit\AREXRevitStart.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (1aa95c7e-ebf6-4205-b465-993f7efdc2e1). }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application AREXRevitStart (be4833f0-363a-4442-82f9-fc2805b4220f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< ::0:: Delta VM: Avail -36 -> 134215931 MB, Used 308 MB, Peak +1 -> 309 MB; RAM: Avail -8 -> 59690 MB, Used +1 -> 455 MB
' 0:< GUI Resource Usage GDI: Avail 9813, Used 187, User: Used 192
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Application, Class: WorkSharingLib.ExternalApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\WorkSharingLib.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6417, name: , text: Launch WSM, class: WorksharingCommand.WorksharingCommand, assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Launch App, Class: WorksharingCommand.WorksharingApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_GO_LIVE' Executed implementation with implementation from application 'Autodesk Revit Live Service' dll 'C:\Program Files\Autodesk\Revit Live\service\DataPrep.RevitAddIn.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Replacing command id 'ID_GO_LIVE' CanExecute implementation with implementation from application 'Autodesk Revit Live Service' dll 'C:\Program Files\Autodesk\Revit Live\service\DataPrep.RevitAddIn.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering ViewActivating event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Autodesk Revit Live Service (0924391b-696d-47f0-add6-92c99445bafe). }
' 0:< API_SUCCESS { Starting External Application: Autodesk Revit Live Service, Class: DataPrep.RevitAddIn.App, Vendor : ADSK(), Assembly: C:\Program Files\Autodesk\Revit Live\service\DataPrep.RevitAddIn.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' Executed implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' CanExecute implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Starting External Application: Communicator for Autodesk Revit, Class: Autodesk.Revit.SmartMonkeyPlugin.SmartMonkeyApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: Communicator\SmartMonkey.dll }
' 0:< API_SUCCESS { Registering Idling event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivating event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo
'Dynamo CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
'Dynamo BeforeExecuted event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll'. }
'Dynamo Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< Third Party Updater 'Dynamo For Revit: Sun and Shadow Settings Updater' registered for all documents.
' 0:< API_SUCCESS { Registering DocumentChanged event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_PLAYLIST_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo Playlist CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_PLAYLIST_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo Playlist Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Starting External Application: Dynamo For Revit, Class: Dynamo.Applications.VersionLoader, Vendor : ADSK(Dynamo), Assembly: C:\Program Files\Dynamo\Dynamo Revit\1.2\Revit_2018\DynamoRevitVersionSelector.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' Executed implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Publish Settings Executed event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' CanExecute implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Publish Settings CanExecute event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Starting External Application: Views For A360, Class: Autodesk.Revit.Addin.ExportViewSelector.ExportViewSelectorApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: .\ExportViewSelectorAddin\ExportViewSelectorAddin.dll }
' 0:< ::0:: Delta VM: Avail -11 -> 134215921 MB, Used +1 -> 309 MB, Peak +1 -> 310 MB; RAM: Avail -8 -> 59682 MB, Used +1 -> 457 MB
' 0:< GUI Resource Usage GDI: Avail 9812, Used 188, User: Used 193
' 0:< API_SUCCESS { Added pushbutton Id: 6418, name: , text: Convert RFA
'to FormIt, class: RFAToAXMAddon.RFAToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6419, name: , text: Convert SKP
'to FormIt, class: RFAToAXMAddon.SketchUpToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6420, name: , text: Import FormIt
'to RVT, class: AXMImportorAddon.AXMImportorCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6421, name: , text: Reload Families, class: AXMImportorAddon.ReloadFamiliesCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6422, name: , text: About FormIt, class: FormItConverter.FormItLink, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\FormItConverterRibbon.dll }
' 0:< ::0:: Delta VM: Avail -5 -> 134215916 MB, Used +14 -> 324 MB, Peak +15 -> 325 MB; RAM: Avail -13 -> 59670 MB, Used +13 -> 470 MB, Peak +11 -> 471 MB
' 0:< GUI Resource Usage GDI: Avail 9810, Used 190, User: Used 194
' 0:< API_SUCCESS { Starting External Application: FormIt Conversion, Class: FormItConverter.Ribbon, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\FormItConverterRibbon.dll }
' 0:< ::0:: Delta VM: Avail -21 -> 134215895 MB, Used +4 -> 328 MB, Peak +9 -> 335 MB; RAM: Avail -4 -> 59667 MB, Used +3 -> 473 MB, Peak +1 -> 473 MB
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_NAVISWORKS' Executed implementation with implementation from application 'File exporter for Navisworks 2018' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application File exporter for Navisworks 2018 (280bb447-f630-48b0-99be-6a776ac7b5c8). }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_NAVISWORKS' CanExecute implementation with implementation from application 'File exporter for Navisworks 2018' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application File exporter for Navisworks 2018 (280bb447-f630-48b0-99be-6a776ac7b5c8). }
' 0:< API_SUCCESS { Registered an external server: Name(Navisworks 2018); VendorId(Autodesk Navisworks); ServerId(68e1934c-ec3b-410c-8c82-434f0cf25446); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Starting External Application: File exporter for Navisworks 2018, Class: NavisWorks15.LcRevitExportApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ./revit_exporter2018.Addin.bundle/nwexportrevit2018/nwexportrevit2018_15.dll }
'C 06-Jul-2017 10:27:40.217; 0:< ->processShellCommand
'E 06-Jul-2017 10:27:40.217; 0:<
Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -19 -> 134215877 MB, Used +6 -> 335 MB; RAM: Avail -12 -> 59655 MB, Used +12 -> 486 MB, Peak +12 -> 486 MB
' 0:< GUI Resource Usage GDI: Avail 9799, Used 201, User: Used 204
'C 06-Jul-2017 10:27:40.389; 0:< <-processShellCommand
'C 06-Jul-2017 10:27:40.389; 0:< ->DesktopMFCApp::doStartupWarnings
'C 06-Jul-2017 10:27:40.389; 0:< License readyForUI
'C 06-Jul-2017 10:27:40.435; 0:< manage debug modes
'C 06-Jul-2017 10:27:40.435; 0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< START CanUseHardware(forced)
' 1:<
'OGS Device Memory Size: 40857 MB
' 1:< ::1:: Delta VM: Avail -32963 -> 134182914 MB, Used +54 -> 390 MB, Peak +56 -> 391 MB; RAM: Avail -9 -> 59646 MB, Used +23 -> 510 MB, Peak +25 -> 511 MB
' 1:< GUI Resource Usage GDI: Avail 9798, Used 202, User: Used 217
' 1:< DX Device: DirectX 11, Hardware
' 1:< DX Device: DirectX 11, WARP
'C 06-Jul-2017 10:27:40.854; 1:< START video card certification
' 1:< ::1:: Delta VM: Avail -19 -> 134182896 MB, Used +3 -> 393 MB, Peak +3 -> 395 MB; RAM: Avail -2 -> 59645 MB, Used +2 -> 512 MB, Peak +4 -> 516 MB
' 1:<
'Current driver version: \Windows\System32\DriverStore\FileRepository\nvcvwu.inf_amd64_398c0a0c4281e441\nvldumdx.dll,C:\Windows\System32\DriverStore\F:22.21.13.8178
'Certified driver(s):
' 1:< VIDEO CARD ENVIRONMENT: CARD="NVIDIA GeForce GTX 1080" ManufacturerID="10DE" DeviceID="1BE0" osID="8000" DRIVER="\Windows\System32\DriverStore\FileRepository\nvcvwu.inf_amd64_398c0a0c4281e441\nvldumdx.dll,C:\Windows\System32\DriverStore\F:22.21.13.8178" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 06-Jul-2017 10:27:40.871; 1:< FINISH video card certification
' 0.431409 1:<<' 0:<
'Can use hardware=y
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=n
'DrvNewerThanTested=n
'CardIsNotListed=y
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 06-Jul-2017 10:27:40.871; 0:< MFCApp::testMSAA
'C 06-Jul-2017 10:27:40.871; 0:< postConditionalWarnings
'C 06-Jul-2017 10:27:40.871; 0:< giveAtomRegistrationWarnings
'C 06-Jul-2017 10:27:40.871; 0:< warnings->consumeAll
'C 06-Jul-2017 10:27:40.871; 0:< Process result of DebugModes-Changed Task Dialog
'C 06-Jul-2017 10:27:40.871; 0:< isMaterialLibraryAvailable
'C 06-Jul-2017 10:27:40.871; 0:< start up warnings for AddIns
'C 06-Jul-2017 10:27:40.872; 0:< <-DesktopMFCApp::doStartupWarnings
'C 06-Jul-2017 10:27:40.873; 0:< <-desktop InitNativeInstance
'C 06-Jul-2017 10:27:40.873; 0:< ->desktop InitManagedInstance
' 1:< API_SUCCESS { Registered an external server: Name(Site Linker); VendorId(ADSK); ServerId(c6c190c2-458e-48ea-ba79-722f26a87b45); ServiceId(c9979a42-11ab-4c25-93e1-abfb50b7be60) }
' 1:< ::1:: Delta VM: Avail -10 -> 134182887 MB, Used +3 -> 396 MB, Peak +2 -> 397 MB; RAM: Avail -20 -> 59626 MB, Used +9 -> 522 MB, Peak +7 -> 523 MB
' 1:< GUI Resource Usage GDI: Avail 9672, Used 328, User: Used 217
' 1:< API_SUCCESS { Added pushbutton Id: 6423, name: , text: Modify, class: REX.AREXRevitMngr.Modifier, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6424, name: , text: Delete, class: REX.AREXRevitMngr.Remover, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6425, name: , text: Preferences, class: REX.AREXRevitMngr.Preferences, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Products\Revit\AREXRevitMngr.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6426, name: , text: Frame Generator, class: REX.DLTFrame3D.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\DLTFrame3D\DLTFrame3D.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6427, name: , text: Grids Generator, class: REX.DRevitGridGenerator.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\DRevitGridGenerator\DRevitGridGenerator.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6428, name: , text: Rafter Framing, class: REX.DRafterFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\DRafterFraming\DRafterFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6429, name: , text: Roof Trusses, class: REX.DRoofTrusses.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\DRoofTrusses\DRoofTrusses.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6430, name: , text: Wood Framing Walls, class: REX.ATimberFraming.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Modeling\ATimberFraming\ATimberFraming.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6431, name: , text: Automatic Reinforcement Generation, class: REX.DReinfAuto.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfAuto\DReinfAuto.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6432, name: , text: Beams, class: REX.DReinfBeam.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfBeam\DReinfBeam.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6433, name: , text: Columns, class: REX.DReinfColumn.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfColumn\DReinfColumn.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6434, name: , text: Continuous Footings, class: REX.DReinfFootingCont.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfFootingCont\DReinfFootingCont.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6435, name: , text: Interferences of Reinforcing Bars, class: REX.DReinfRebarCollisions.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfRebarCollisions\DReinfRebarCollisions.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6436, name: , text: Parapets, class: REX.DReinfParapet.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfParapet\DReinfParapet.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6437, name: , text: Pile Caps, class: REX.DReinfPileCap.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfPileCap\DReinfPileCap.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6438, name: , text: Piles, class: REX.DReinfPile.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfPile\DReinfPile.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6439, name: , text: Retaining Walls, class: REX.DReinfRetainingWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfRetainingWall\DReinfRetainingWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6440, name: , text: Slab Corners, class: REX.DReinfSlabCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfSlabCorner\DReinfSlabCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6441, name: , text: Slab Openings, class: REX.DReinfSlabOpening.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfSlabOpening\DReinfSlabOpening.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6442, name: , text: Spread Footings, class: REX.DReinfFootingSpread.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfFootingSpread\DReinfFootingSpread.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6443, name: , text: Wall Corners, class: REX.DReinfWallCorner.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfWallCorner\DReinfWallCorner.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6444, name: , text: Walls, class: REX.DReinfWall.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Reinforcement\DReinfWall\DReinfWall.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6445, name: , text: Compare Models, class: REX.DRevitModelsCompare.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Tools\DRevitModelsCompare\DRevitModelsCompare.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6446, name: , text: Element Positioning, class: REX.DElementsPositioning.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\Tools\DElementsPositioning\DElementsPositioning.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6447, name: , text: Reinforcement Code Check, class: REX.DReinfDesign.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\RSA\DReinfDesign\DReinfDesign.dll }
' 1:< API_SUCCESS { Added pushbutton Id: 6448, name: , text: Robot Structural Analysis Link, class: REX.DRevit2Robot.DirectRevitAccess, assembly: C:\Program Files\Common Files\Autodesk Shared\Extensions 2018\Modules\RSA\DRevit2Robot\DRevit2Robot.dll }
' 1:< ::1:: Delta VM: Avail -12 -> 134182875 MB, Used +1 -> 397 MB; RAM: Avail -7 -> 59619 MB, Used +2 -> 525 MB, Peak +2 -> 525 MB
' 1:< GUI Resource Usage GDI: Avail 9664, Used 336, User: Used 217
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfBeam' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfColumn' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfFootingSpread' registered for all documents.
' 1:< Third Party Updater 'AREXRevitStart: REXExtension: DReinfWall' registered for all documents.
' 1:< API_SUCCESS { Registering DocumentOpened event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DocumentCreated event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering DisplayingOptionsDialog event by application AREXRevitStart (c0566ed7-4309-4082-b3ba-ea6b7b4d292a). }
' 1:< API_SUCCESS { Registering ViewActivated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
'C 06-Jul-2017 10:27:42.891; 0:< <-desktop InitManagedInstance
' 0:< ::1:: Delta VM: Avail -40 -> 134182836 MB, Used +5 -> 403 MB, Peak +5 -> 403 MB; RAM: Avail -24 -> 59596 MB, Used +23 -> 548 MB, Peak +23 -> 548 MB
' 0:< GUI Resource Usage GDI: Avail 9635, Used 365, User: Used 221
'C 06-Jul-2017 10:27:43.116; 0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:< BuildNumber : 14393
' 0:< BuildType : Multiprocessor Free
' 0:< Caption : Microsoft Windows 10 Pro
' 0:< CodeSet : 1252
' 0:< CountryCode : 1
' 0:< FreePhysicalMemory : 61024004
' 0:< FreeSpaceInPagingFiles : 9961472
' 0:< FreeVirtualMemory : 70843724
' 0:< MaxProcessMemorySize : 137438953344
' 0:< OSLanguage : 1033
' 0:< OSType : 18
' 0:< ServicePackMajorVersion : 0
' 0:< ServicePackMinorVersion : 0
' 0:< TotalVirtualMemorySize : 77026692
' 0:< TotalVisibleMemorySize : 67065220
' 0:< Version : 10.0.14393
' 0:< ::1:: Delta VM: Avail -11 -> 134182826 MB, Used +1 -> 405 MB, Peak +2 -> 405 MB; RAM: Avail -10 -> 59587 MB, Used +2 -> 551 MB, Peak +3 -> 551 MB
' 0:< GUI Resource Usage GDI: Avail 9635, Used 365, User: Used 229
' 0:< Process affinity mask : FF
' 0:< System affinity mask : FF
' 0:< ::1:: Delta VM: Avail 134182826 MB, Used 405 MB, Peak +1 -> 406 MB; RAM: Avail +14 -> 59602 MB, Used 551 MB, Peak +0 -> 552 MB
' 0:< GUI Resource Usage GDI: Avail 9635, Used 365, User: Used 228
' 0:< PROCESSOR INFORMATION:
' 0:< AddressWidth : 64
' 0:< Architecture : 9
' 0:< Availability : 3
' 0:< Caption : Intel64 Family 6 Model 94 Stepping 3
' 0:< CurrentClockSpeed : 4001
' 0:< DataWidth : 64
' 0:< Description : Intel64 Family 6 Model 94 Stepping 3
' 0:< Family : 198
' 0:< L2CacheSize : 1024
' 0:< Level : 6
' 0:< Manufacturer : GenuineIntel
' 0:< MaxClockSpeed : 4001
' 0:< Name : Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
' 0:< ProcessorType : 3
' 0:< Revision : 24067
' 0:< Role : CPU
' 0:< SocketDesignation : U3E1
' 0:< StatusInfo : 3
' 0:< Version :
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:< AdapterCompatibility : NVIDIA
' 0:< AdapterDACType : Integrated RAMDAC
' 0:< AdapterRAM : -1048576
' 0:< Caption : NVIDIA GeForce GTX 1080
' 0:< CurrentBitsPerPixel : 32
' 0:< CurrentHorizontalResolution : 1920
' 0:< CurrentNumberOfColors : 4294967296
' 0:< CurrentRefreshRate : 75
' 0:< CurrentVerticalResolution : 1080
' 0:< Description : NVIDIA GeForce GTX 1080
' 0:< DriverDate : 20170412000000.000000-000
' 0:< DriverVersion : 22.21.13.8178
' 0:< MaxRefreshRate : 75
' 0:< MinRefreshRate : 75
' 0:< Monochrome : 0
' 0:< Name : NVIDIA GeForce GTX 1080
' 0:< VideoArchitecture : 5
' 0:< VideoMemoryType : 2
' 0:< VideoModeDescription : 1920 x 1080 x 4294967296 colors
' 0:< VideoProcessor : GeForce GTX 1080
' 0:< ::1:: Delta VM: Avail 134182826 MB, Used 405 MB; RAM: Avail -40 -> 59562 MB, Used +0 -> 552 MB, Peak +0 -> 553 MB
'E 06-Jul-2017 10:27:46.254; 0:<
Jrn.AppButtonEvent 1 , "Application Menu is opening"
' 0:< ::2:: Delta VM: Avail -3 -> 134182824 MB, Used +1 -> 406 MB, Peak +0 -> 407 MB; RAM: Avail -31 -> 59531 MB, Used +4 -> 557 MB, Peak +4 -> 557 MB
' 0:< GUI Resource Usage GDI: Avail 9627, Used 373, User: Used 236
' 0:< PRINTER INFORMATION:
' 0:< Caption : Send To OneNote 2016
' 0:< Default : 0
' 0:< DeviceID : Send To OneNote 2016
' 0:< Direct : 0
' 0:< DriverName : Send to Microsoft OneNote 16 Driver
' 0:< EnableBIDI : 0
' 0:< EnableDevQueryPrint : 0
' 0:< HorizontalResolution : 600
' 0:< Local : -1
' 0:< Name : Send To OneNote 2016
' 0:< Network : 0
' 0:< PortName : nul:
' 0:< PrintJobDataType : RAW
' 0:< PrintProcessor : winprint
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< SpoolEnabled : -1
' 0:< VerticalResolution : 600
' 0:< Caption : NPIC5A415 (HP PageWide XL 5000PS MFP)
' 0:< Default : 0
' 0:< DeviceID : NPIC5A415 (HP PageWide XL 5000PS MFP)
' 0:< Direct : 0
' 0:< DriverName : HP Designjet T Series PS Class Driver
' 0:< Local : -1
' 0:< Name : NPIC5A415 (HP PageWide XL 5000PS MFP)
' 0:< Network : 0
' 0:< PortName : WSD-a4734973-8636-45cc-87ee-e6993dde7623.0035
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft XPS Document Writer
' 0:< Default : 0
' 0:< DeviceID : Microsoft XPS Document Writer
' 0:< Direct : 0
' 0:< DriverName : Microsoft XPS Document Writer v4
' 0:< Local : -1
' 0:< Name : Microsoft XPS Document Writer
' 0:< Network : 0
' 0:< PortName : PORTPROMPT:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft Print to PDF
' 0:< Default : 0
' 0:< DeviceID : Microsoft Print to PDF
' 0:< Direct : 0
' 0:< DriverName : Microsoft Print To PDF
' 0:< Local : -1
' 0:< Name : Microsoft Print to PDF
' 0:< Network : 0
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Fax
' 0:< Default : 0
' 0:< DeviceID : Fax
' 0:< Direct : 0
' 0:< DriverName : Microsoft Shared Fax Driver
' 0:< HorizontalResolution : 200
' 0:< Local : -1
' 0:< Name : Fax
' 0:< Network : 0
' 0:< PortName : SHRFAX:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 200
' 0:< Caption : Bluebeam PDF
' 0:< Default : -1
' 0:< DeviceID : Bluebeam PDF
' 0:< Direct : 0
' 0:< DriverName : BluebeamPSDriver
' 0:< Local : -1
' 0:< Name : Bluebeam PDF
' 0:< Network : 0
' 0:< PortName : BLUEBEAMPDFPORT
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Adobe PDF
' 0:< Default : 0
' 0:< DeviceID : Adobe PDF
' 0:< Direct : 0
' 0:< DriverName : Adobe PDF Converter
' 0:< HorizontalResolution : 1200
' 0:< Local : -1
' 0:< Name : Adobe PDF
' 0:< Network : 0
' 0:< PortName : Documents\*.pdf
' 0:< RawOnly : -1
' 0:< Shared : 0
' 0:< VerticalResolution : 1200
' 0:< Caption : \\fs1\142 Ricoh plotter
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Ricoh plotter
' 0:< Direct : 0
' 0:< DriverName : Gestetner GWD3006 PS
' 0:< EnableBIDI : -1
' 0:< Local : 0
' 0:< Name : \\fs1\142 Ricoh plotter
' 0:< Network : -1
' 0:< PortName : 192.168.37.155
' 0:< PrintProcessor : E150PP64
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\140 Toshiba C
' 0:< Default : 0
' 0:< DeviceID : \\fs1\140 Toshiba C
' 0:< Direct : 0
' 0:< DriverName : TOSHIBA Universal Printer 2
' 0:< Local : 0
' 0:< Name : \\fs1\140 Toshiba C
' 0:< Network : -1
' 0:< PortName : 10.120.223.113_1
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 Canon ipf815 (new on right)
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Canon ipf815 (new on right)
' 0:< Direct : 0
' 0:< DriverName : Canon iPF815
' 0:< Local : 0
' 0:< Name : \\fs1\142 Canon ipf815 (new on right)
' 0:< Network : -1
' 0:< PortName : 192.168.37.249_1
' 0:< PrintProcessor : Canon iPF815 Print Processor
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 HP Pagewide 5000 PS
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 HP Pagewide 5000 PS
' 0:< Direct : 0
' 0:< DriverName : HP PageWide XL 5000PS MFP PS3
' 0:< Local : 0
' 0:< Name : \\fs1\142 HP Pagewide 5000 PS
' 0:< Network : -1
' 0:< PortName : 10.120.223.168
' 0:< PrintProcessor : hpipp151
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 Ricoh copier upstairs (stapler)
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Ricoh copier upstairs (stapler)
' 0:< Direct : 0
' 0:< DriverName : SAVIN MP 5002 PCL 6
' 0:< Local : 0
' 0:< Name : \\fs1\142 Ricoh copier upstairs (stapler)
' 0:< Network : -1
' 0:< PortName : 192.168.37.141
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 Canon ipf815 plotter
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Canon ipf815 plotter
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Name : \\fs1\142 Canon ipf815 plotter
' 0:< Network : -1
' 0:< PortName : 192.168.37.252
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\179 lincoln st Canon iPF815
' 0:< Default : 0
' 0:< DeviceID : \\fs1\179 lincoln st Canon iPF815
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Name : \\fs1\179 lincoln st Canon iPF815
' 0:< Network : -1
' 0:< PortName : 192.168.40.222
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\Oce PlotWave 365 Right
' 0:< Default : 0
' 0:< DeviceID : \\fs1\Oce PlotWave 365 Right
' 0:< Direct : 0
' 0:< DriverName : Oce PlotWave 365 PS
' 0:< Local : 0
' 0:< Name : \\fs1\Oce PlotWave 365 Right
' 0:< Network : -1
' 0:< PortName : 10.120.223.152_PW365
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\Oce PlotWave 365 Left
' 0:< Default : 0
' 0:< DeviceID : \\fs1\Oce PlotWave 365 Left
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Name : \\fs1\Oce PlotWave 365 Left
' 0:< Network : -1
' 0:< PortName : 10.120.223.153_PW365
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 11x17 color
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 11x17 color
' 0:< Direct : 0
' 0:< DriverName : Brother MFC-J6720DW Printer
' 0:< Local : 0
' 0:< Name : \\fs1\142 11x17 color
' 0:< Network : -1
' 0:< PortName : WSD-bef11bf2-7cce-4b5a-b63a-1e19dbcddc64.0034
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\HP PageWide XL 5000PS MFP HPGL2
' 0:< Default : 0
' 0:< DeviceID : \\fs1\HP PageWide XL 5000PS MFP HPGL2
' 0:< Direct : 0
' 0:< DriverName : HP PageWide XL 5000PS MFP HPGL2
' 0:< Local : 0
' 0:< Name : \\fs1\HP PageWide XL 5000PS MFP HPGL2
' 0:< Network : -1
' 0:< PrintProcessor : hpipp161
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Default : 0
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Network : -1
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 24" Canon Plotter
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 24" Canon Plotter
' 0:< Direct : 0
' 0:< Local : 0
' 0:< Name : \\fs1\142 24" Canon Plotter
' 0:< Network : -1
' 0:< PortName : 192.168.37.174
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\fs1\142 Canon copier downstairs
' 0:< Default : 0
' 0:< DeviceID : \\fs1\142 Canon copier downstairs
' 0:< Direct : 0
' 0:< DriverName : Canon iR-ADV 4225/4235 PCL5e
' 0:< Local : 0
' 0:< Name : \\fs1\142 Canon copier downstairs
' 0:< Network : -1
' 0:< PortName : 192.168.37.250_2
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Send To OneNote 2016
' 0:< DriverVersion : 1539
' 0:< Orientation : 1
' 0:< PaperLength : 2794
' 0:< PaperSize : Letter 8 1/2 x 11 in
' 0:< PaperWidth : 2159
' 0:< PrintQuality : 600
' 0:< SpecificationVersion : 1025
' 0:< XResolution : 600
' 0:< YResolution : 600
' 0:< Copies : 1
' 0:< Description : NPIC5A415 (HP PageWide XL 5000PS MFP)
' 0:< MediaType : 256
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft XPS Document Writer
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft Print to PDF
' 0:< Color : 1
' 0:< Description : Fax
' 0:< DriverVersion : 1024
' 0:< Duplex : 0
' 0:< PrintQuality : 200
' 0:< XResolution : 200
' 0:< YResolution : 200
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Bluebeam PDF
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Adobe PDF
' 0:< PrintQuality : 1200
' 0:< XResolution : 1200
' 0:< YResolution : 1200
' 0:< Description : \\fs1\142 Ricoh plotter
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\fs1\140 Toshiba C
' 0:< Duplex : 0
' 0:< Description : \\fs1\142 Canon ipf815 (new on right)
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\fs1\142 HP Pagewide 5000 PS
' 0:< MediaType : 1
' 0:< Orientation : 2
' 0:< Description : \\fs1\142 Ricoh copier upstairs (stapler)
' 0:< Description : \\fs1\142 Canon ipf815 plotter
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\fs1\179 lincoln st Canon iPF815
' 0:< DriverVersion : 1067
' 0:< Description : \\fs1\Oce PlotWave 365 Right
' 0:< Description : \\fs1\Oce PlotWave 365 Left
' 0:< Description : \\fs1\142 11x17 color
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\fs1\HP PageWide XL 5000PS MFP HPGL2
' 0:< MediaType : 1
' 0:< Color : 2
' 0:< Copies : 1
' 0:< MediaType : 1
' 0:< Description : \\fs1\142 24" Canon Plotter
' 0:< Copies : 1
' 0:< Description : \\fs1\142 Canon copier downstairs
' 0:< DriverVersion : 5381
' 0:< Duplex : -1
' 0:< ::2:: Delta VM: Avail 134182824 MB, Used 406 MB; RAM: Avail -14 -> 59518 MB, Used 557 MB
' 0:< GUI Resource Usage GDI: Avail 9627, Used 373, User: Used 237
'E 06-Jul-2017 10:27:47.182; 0:<
Jrn.AppButtonEvent 0 , "Application Menu is closing"
'E 06-Jul-2017 10:27:47.208; 0:<
Jrn.Command "Ribbon" , "Open an existing project , ID_REVIT_FILE_OPEN"
Message 18 of 21
jelwell3QWFZ
Are you running Ultra-mon or another desktop organizer for multiple monitors? That’s the problem with mine and when I turn it off it works as intended. Unfortunately it seems like Revit 2018 is not built to work with Ultra-mon but I’m hoping they can patch that because I can’t imagine not using one. Is there one Autodesk recommends I wonder?
If it works hit me with a solved!
Message 19 of 21
BlairmackNZ
Hi jelwell3QWFZ
You've got it. Ultramon was the culprit on mine also. Wonder what Autodesk have done to change things between releases as I'm also running 2014-2016 on the same machine with not problems.
Thanks for sharing your success, and really pleased to have the issue sorted.
blairmack
Message 20 of 21
Yes UltraMon was the issue with us also. Just go to run and type in msconfig, go to start-up and uncheck UltraMon, apply, then reboot the machine.
I wish AutoDesk would succumb to the reality that everyone in our industry is using dual monitors and design the software to efficiently use both monitors.
