After installing Revit 2018, libraries are non-existent here C:\ProgramData\Autodesk\RVT 2018\Libraries\US Imperial and US Metric and templates are non-existent here C:\ProgramData\Autodesk\RVT 2018\Libraries\US Imperial and US Metric. I have done some research and found a post to make sure the master.xml file is located within the \Content\Revit folder (which it is) and also tried to reinstall the Content Libraries, but had no luck. I have also tried to run the .msi file here C:\Autodesk\Revit_2018_G1_Win_64bit_dlm\Content\ADSKMaterials\2018\CM. Has anyone else experienced this or can provide a download link for the Libraries?
Solved by Viveka_CD. Go to Solution.
For the time being - do you have your old templates and libraries? Revit 2018 will be able to open and use them just as well.
Hi @Anonymous
Please see HERE for solutions on missing the templates and families (applies to Revit 2018)
See a similar discussion HERE and HERE to follow reply by @pavilionconsult
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Viveka CD
