Revit 2018 to DiaLux Evo 8.0
SezaiErcan
Message 1 of 13
SezaiErcan
Hi everybody.
I am trying to import a model from Revit to DiaLux. I searched some ways to do that in internet and i found that i should use IFC File. However, it takes really really really long time ( like 4-5 hours ) . After these unsuccessful tryings, i closed Curtain wall's visibility and then Exported IFC file again. With that way , when i import IFC File without curtain wall , it just takes 2-3 minutes and works properly.
here is my question : Is there any spesific way to import revit models to Dialux Environment ?
Replies (12)
Message 2 of 13
Viveka_CD
Hi @SezaiErcan
As the first step, have you installed the latest updates for Revit 2018?
Next, can you confirm if you are using IFC for Autodesk® Revit® 2018?
By default, Revit uses the appropriate IFC mapping file when you export a project to IFC. For building elements that do not have an automatic mapping to IFC export classes, the value displayed in the IFC Class Name column is 'Not Exported'. In the case of a Curtain wall - it is represented as a building element assembly and implemented as a subtype of walls, panels, and geometry.
As an alternative, you can also try Relux, see support solutions
You are welcome to share a file with us to test the import.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Message 3 of 13
SezaiErcan
Dear @Viveka_CD
Thank you for your answer.
I have tryed or viewed everything you said to solve the problem. I think The IFC plug-in solved some problems because it is faster than before. But it still is so so long , ( 2-3 hours ).
After my post on Autodesk Revit Forum, I got in contact with 'Dialux Team', sent the IFC files and explained what the problem is.  In their answer , they told me that they couldn't solve the problem but they will try to improve their Import settings for IFC files. If they find a way to solve this problem , they will release an update.
Before these , If I find a solution , I will definitely inform you.
Unfortunately, we couldn't find a way yet, but i believe we will.
Regards.
Message 4 of 13
Viveka_CD
Hi @SezaiErcan
Thanks for getting back.
Let me know how it goes.
Can you share your files? I can test it on our end. Let me know and I can send you a private folder to upload.
Message 5 of 13
SezaiErcan
I am really appreciated about your helps @Viveka_CD. I would like to share the files. Private folder would be better for me . Hope we can reach the solution.
Be sure about that I will inform you if i get an e-mail from DiaLux Team or find a way .
Best Regards.
Message 6 of 13
Viveka_CD
Hi @SezaiErcan
I've shared a private folder with you.
Please upload your files and let me know if you have trouble accessing this folder.
Thanks!
Message 7 of 13
SezaiErcan
Hi @Viveka_CD
I've uploaded files to folder. Thank you a lot.
Regards.
Message 8 of 13
Viveka_CD
Hi @SezaiErcan
Thanks for the update. I got your files.
Can you please upload your recent journal file too?
Message 9 of 13
SezaiErcan
Dear @Viveka_CD
I've uploaded journal files.
Thanks. Regards.
Message 10 of 13
SezaiErcan
Hi @Viveka_CD
Is there any solutioun you found ? Hope it is.
Regards.
Message 11 of 13
Viveka_CD
Hi @SezaiErcan
Thanks or checking back in. The issue is under investigation.
I can confirm that I recreated the behavior on my side, but it happens only for this particular project of yours.
Thank you again for your patience while we are trying to identify what is causing this behavior.
Message 12 of 13
jeamy.baena
Hi, @Viveka_CD and @SezaiErcan
Any news or feedback for this case is really appreciated!!
Thanks!!
Message 13 of 13
syman2000
Not sure if anyone found a solution. I have a work around that allows the object to translate properly with Dialux from Revit. First you need to install Revit to ArchiCAD IFC plugin
https://www.graphisoft.com/downloads/interoperability.html
Once you installed it, change the setting and set the object to High
If you choose low or other setting, the wall may not display correctly. Also note if you have curtainwall embedded into the wall, IFC export will show as solid wall. This is the only issue I encounter so far. Overall it translate to DiaLux and our consultant is happy with the result.
