Revit 2018 slow in Windows 10
17 REPLIES 17
Message 1 of 18
MachielAEC
1811 Views, 17 Replies
Hi All,
I would like to find out if anybody has found that Revit Projects are running slow on Windows 10 OS.
Having a problem where I'm opening up a file on a Windows 7 PC and the file is working fine (slowness due to file size) with a full building with all links in 3D view. When I open the same file on a Windows 10 PC the file is super laggy when I only have some links loaded and a section box around 1 floor level.
The specs of the PC's is the same, the major difference is that the Win 10 PC has more recent hardware - i7-7700
Windows 7 PC
Windows 10 PC
Machiel Odendaal
---BIM Enthusiast---
17 REPLIES 17
Message 2 of 18
ennujozlagam
in reply to: MachielAEC
Have you try to install latest updates 2018.1, 2018.2, 2018.3, 2018.31 and see if helps. Thanks
Message 3 of 18
MachielAEC
in reply to: ennujozlagam
All the systems are running on the same version number (RVT 2018.2) which in essence shouldn't make a difference between Revit on differente PC's.
Machiel Odendaal
Message 4 of 18
Viveka_CD
Hi @MachielAEC
Revit 2018.3.1* is the latest update. Make sure your team is on the same build.
Message 5 of 18
MachielAEC
in reply to: Viveka_CD
@Viveka_CD
So I've reqeusted that they update to the latest build. As mentioned previously, I do believe that updating to 2018.3.1 will be the solution as all the Revit builds in the office is on 2018.2 - no difference between builds.
What was interesting was that if you open Revit in Win7 Compatibility mode it runs better, not the same as the Win 7 PC's.
Machiel Odendaal
Message 6 of 18
Viveka_CD
@MachielAEC
Let me know how it goes!
Interesting to note the difference between the windows platforms.
Message 7 of 18
SEFLIL
Bump
I´ve the same problem. Does anyone have the solution?
Message 8 of 18
Viveka_CD
in reply to: SEFLIL
Hi @SEFLIL
Can you specify more details of what you are experiencing?
See article on Revit slow performance
Message 9 of 18
SEFLIL
Generally slow, very difficult to write text, drag symbols etc.
My IT-support told me, that it´s a problem Autodesk is working on to get us a solution
Message 10 of 18
Viveka_CD
in reply to: SEFLIL
Message 11 of 18
SEFLIL
Ok, please do that!
Message 12 of 18
Viveka_CD
in reply to: SEFLIL
Hi @SEFLIL
I've shared a private upload folder with you, let me know if you have trouble accessing the folder.
Message 13 of 18
SEFLIL
I´ve upploaded the file. Let me know if there is anything else you need!
Message 14 of 18
Viveka_CD
in reply to: SEFLIL
Awesome @SEFLIL
I'll take a look at your data-set, and let you know.
Message 15 of 18
SEFLIL
Hello!
I just wanted to share my solution to this problem. I´ve disabled the "defendpoint" on my computer. This solved my problems, I hope it solves others with similar issues!
Message 16 of 18
Viveka_CD
in reply to: SEFLIL
Hi @SEFLIL
Thanks for getting back to update us.
Glad this helped resolve your issue.
Message 17 of 18
MachielAEC
in reply to: SEFLIL
Thank you, will give it a try.
Machiel Odendaal
Message 18 of 18
we have a similar problem - revit 2018 keeps hanging every 30 seconds - any help is appreciated...thanks
