Reference drafting views from a master model
9 ANTWORTEN 9
Nachricht 1 von 10
708 Aufrufe, 9 Antworten
There are a lot of typical details that can be shared between projects. We are wondering if there is a way to keep all of the typical details in one model and it can be referenced from other models, so we don’t have to duplicate all of them into different models and if there is a change, we only need to do it in one location.
I came across this software called ViewAQC in Autodesk forum, and it does what we are looking for, but we currently don't have this in the company. Does anyone have other solutions?
https://26degreessoftware.com/about-us
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
What about Load as Group or Insert from File?
Nachricht 3 von 10
als Antwort auf: barthbradley
If I need to change one detail, I will need to make sure I load it back to all of the models have it.
Nachricht 4 von 10
Do you work for ViewAQC?
Nachricht 5 von 10
Draw details in a master file as floor plan detail views, not drafting views. Link it in your project and use by linked view.
Nachricht 6 von 10
als Antwort auf: ToanDN
I see. Similar to floor plan, do you also use live section/ elevations for those callouts?
Nachricht 7 von 10
No. Use Reference other view for callouts.
Nachricht 8 von 10
BDMackey
Nachricht 9 von 10
als Antwort auf: BDMackey
This method is awesome! Thank you!!!
Nachricht 10 von 10
BDMackey
@Anonymous Glad you like it.  As I say often in the presentation. It does take alot of set up, but once it is done the process is amazing.
