Revit 2018 Ribbon Freezing
Quinn_Knudsen2
Message 1 of 22
Quinn_Knudsen2
Good afternoon all,
We have just started switching to 2018 for all new work for the year. There are three of us using R2018 in our group at the moment, and all of us experience the same issue. The entire ribbon will freeze and not allow any click to change it. However, Revit itself is not frozen. The ribbon has frozen during several different operations; I can't find that it's caused by the same action. Sometimes after a few minutes of random clicking it will unfreeze itself but most of the time it will require a full close/restart. Since it seems to be happen at least once or twice a day with us, I'm curious if anyone else is having the same issue, and if so, has found a fix.
Thanks!
Replies (21)
Message 2 of 22
2018.2?
Message 3 of 22
Are your Windows 10s recently updated to 1709 build?
Message 4 of 22
Quinn_Knudsen2
Yes, we're running 2018.2, but I'm on Windows 10 1607. Is there a compatibility issue with old versions of Windows and 2018.2?
Message 5 of 22
No. There are performance issues related to the Fall creation update (1709) but looks like this is not the case.
Message 6 of 22
Quinn_Knudsen2
So should we just assume that we have a corrupt install across all platforms? It happens quite frequently so we'd like to get a solution for this as quickly as possible.
Message 7 of 22
Viveka_CD
Hi @Quinn_Knudsen2
I see that you are visiting as a new member.Welcome to the Autodesk Community!
A few recommendations:
If all the above fails to resolve your issue, it could be a corrupt installation of Revit. Reinstall recommended
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Message 8 of 22
Quinn_Knudsen2
Viveka,
This is NOT the solution to our problem. We are going through the states of testing all of these ideas on our machines and none of them have been conclusive yet. As you were the one who decided to mark your own response as a solution, please unmark your response as a solution as it is not.
Message 9 of 22
Viveka_CD
Hi @Quinn_Knudsen2
No worries, it will be unmarked.
Usually a solution is marked if this works during testing and to help other find solutions quickly.
Since you are in the process of trying the suggestions, we will wait to hear back from you on which of the recommendations helped, then we can mark that answer as solution.
Thanks!
Message 10 of 22
Hi. I'm facing the same issue. My system configuration meets all the requirements.
Message 11 of 22
Quinn_Knudsen2
We've found that it's an error within Revit 2018 that occurs after loading a family into a project. It doesn't matter what type of family, just as long as you click on "Load Family." The 'fix' for it that we've found is to restore down and then maximize the window (the box next to the 'X' at top right of Revit window) (double clicking on the top of the Revit window twice also works). This resets the ribbon so that it's usable again.
Message 12 of 22
Viveka_CD
Hi @Anonymous
Please try the below steps and let me know if this helps!
  1. Browse to the following path:
         C:\Users\%USERNAME%\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2018
  1. Open the Revit.ini file in Notepad.
  2. Delete all of the entries at the end of the file after the line "[Recent File List]" (including "[Recent Workset List]").
Alternative option: Delete the Revit.ini file and it would then be recreated automatically (when launching/closing Revit).
Note: If you delete the Revit.ini file, then Revit configuration options stored in this file will be reset to their defaults.
Message 13 of 22
Quinn_Knudsen2
Hey Viveka,
I've forwarded this on to our IT guys to see if we can use this as a solution. I'll be sure to come back and mark it as a solution if it ends up working. Thanks!
Message 14 of 22
markcalloway
Please make sure you have Microsoft .Net Framework 4.6 installed. If its a different version whether older of newer then uninstall and install 4.6 and see how you get on.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
Message 15 of 22
Viveka_CD
@Quinn_Knudsen2 wrote:
Hey Viveka,
Sure @Quinn_Knudsen2  keep me posted:)
Message 16 of 22
Viveka_CD
Message 17 of 22
Quinn_Knudsen2
@Viveka_CD We're still working on it. We've just tried it on two machines yesterday and haven't heard back. We're a big company - things move slowly.
Message 18 of 22
Quinn_Knudsen2
@Viveka_CD This doesn't turn out to be a solution. I just tested it several times and get the same results. Load Family > *Pick a family to Load* > Revit ribbon freezes. Restoring Down and Maximizing the Revit window fixes the freeze.
Message 19 of 22
Viveka_CD
@Quinn_Knudsen2
Are you having multiple monitors, there could be something else going on.
Please contact support and log a case, its best that we remote into your machine to investigate further.
Message 20 of 22
jbayer_dlr
Did this problem every get solved?  We are currently working through the exact same issue, first suggestions now.
