Revit 2018 on Windows 10 Bootcamp Print to PDF text issues...
Bellhaus
Bellhaus
Can anyone please help?
Everything appears fine in the program but printing to PDF or direct to printer seems to skew / change and overlap all text within drawings?
markcalloway
Hi @Bellhaus
What PDF printer are you using?
Firstly you need to work out if this is a Revit issue or PDF printer issue. If you can use another PDF printer to test this will tell us where the issue is.
You can download CutePDF for free here if you need another PDF printer:
http://www.cutepdf.com/Products/CutePDF/writer.asp
I look forward to your reply.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
Bellhaus
Hi Mark,
I'm currently using Cute PDF which is running through other applications fine.
It seems to be an issue with Revit as all other applications are printing fine. I've attached some screen shots for your info.
markcalloway
Hi @Bellhaus
It would still be good to try a second PDF printer, even if it works fine with other applications.
Also if you have access to a normal printer can you test to see how that prints out and let us know the results.
Bellhaus
Thanks Mark.
I have tried both acrobat and Microsoft PDF and the same issue occurs.
Printing to a regular printer has the same results also
markcalloway
Hi @Bellhaus
Is it possible to upload the title block so I may take a look at it and test it on my computer as I have Revit 2018 on Windows 10 too.
Also please make sure you have updated Revit to the latest service pack (2018.3.1*).
