Revit 2018 inclined floor
7 REPLIES 7
Message 1 of 8
943 Views, 7 Replies
How do i make an inclined floor with the thickness of the floor getting smaller through the incline? I would like to have 200 thickness on one side and 180 thickness om the other with and the incline should be -20.
7 REPLIES 7
Message 2 of 8
cbcarch
A few methods:
-Model in-place>Extrusion.
Sketch the profile needed, then create the floor., Grip edit length in Plan view. Set Family Type to Floor.
-Use an in-place Void to cut a floor that is level.
-You could also try to use a Ramp.
-You can use edit sub-elements/points to give the top surface of the floor a slope as needed.
-You can use a slope arrow ( this will "tilt" the whole floor, top and bottom surfaces)
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 8
Create a 200 mm flat floor and edit sub elements to bring the end edge down 20 mm.
Message 4 of 8
in reply to: ToanDN
Can't i just change the elevation at the bottom? As in the picture, but how do i change the setting when it is grey?
Message 5 of 8
See below.  And if you read my first post carefully you would notice I said "flat floor".
Message 6 of 8
How'd I do @Anonymous?
Message 7 of 8
Message 8 of 8
in reply to: ToanDN
Thank you that worked 😄
