Revit 2018 in 2017
Revit 2018 in 2017
Message 1 of 47
Revit 2018 in 2017
Is there ANY way to convert a Revit 2018 file to Revit 2017?
Can I save it on Navisworks and then Revit 2017?
Can I save it on IFC and then Revit 2017?
Any ideas are welcome!
Replies (46)
Message 41 of 47
chrisplyler
You just hit the Reply button, Quoted my post, and didn't add anything in reply?
Message 42 of 47
It got added to the quote....lol
The forum has that awkward issue if you start typing something, then backspace then click quote, it won't let you add anything after the quote.  I usually just cancel and start over so people don't think I'm weird and just repeating what they just said.
Message 43 of 47
chrisplyler
@benj wrote:
You don't need to tell me the difference from 2d to 3d. I know that. I'm a licensed architect since 1986. The software in general NEEDS TO BE BACKWARD Compatible.
For some reason an outsource ally in the business uses '18 & the current project on site is still '17. Simply save saveas 2017 version is IDEAL.
Sorry...I didn't see the content you typed into the quote.
Um...you obviously don't understand the question I asked. I did not tell you the difference between 2d and 3d.
This is way oversimplified, but boiled down to the very basics, Autocad is a very fancy set of tools for making lines between points. Those points can have Z values, and thus Autocad is 3d capable. But still, the data it keeps in it's file format, again way oversimplified, is a list of points that have lines between them. You can put out a new version, adding all sorts of new tools for drawing lines between points, and still the file format can remain the same, because it doesn't care about which tool you used to draw the lines between points, it only cares about keeping track of the points.
Revit is a completely different animal.
I asked you a question. I'm trying to help you understand something. I'll ask it again.
If Revit adds a new feature...let's say something like vertical wall reveals...how can you possibly expect a model containing such a feature to work in an older version of Revit that did not have vertical wall reveals? Where would the parameters for the new feature be stored in the older database format?
Message 44 of 47
The argument always comes up that "ArchiCAD is backwards compatible!"   But your comment here Chris is the same for ArchiCAD, as what you will get are black dots that look the same like Revit's Analytical points because the older version cannot support the new functionality.  I once saved back an AC file quite a few versions for a consultant and he complained that all he got was walls and dots.  I still had the version on another computer and he was right, the model was littered with dots.  Wound up exporting DWG files instead.
Message 45 of 47
chrisplyler
Soooooo... what you are saying is that although Archicad can save to older versions, it isn't really "compatible" either. Doesn't make my explanation of why it would be a terrible nightmare to make Revit backwards compatible any less valid. Sure, you could make it save to older versions and just throw out everything you did that the older versions can't handle, and in this way you could save all the old, useless files your heart desires. I don't really think that's what people want in this thread.
Message 46 of 47
Yeah, but AC's performance only got better when you got new hardware, unlike Revit which has improved significantly over the years as performance tweaks were added with each release.  Sure, we may not get the functionality or tools we were hoping for, but we get more stability.   I can't even remember the last time Revit crashed on me, and my computer is pushing 7 years.
Message 47 of 47
chrisplyler
I totally agree with that. But the topic wasn't comparing and contrasting Archicad with Revit.
