Revit Shortcut - Rotate 90 Degrees?
VicBerg
Message 1 of 11
VicBerg
Hi, I need some help to create a shortcut that i can rotate an modelgroup in 90 degrees jumps. I did try to ad a command for the already listed "rotate 90" in revit shortcut list but it dosnt work. Does anyone know a solution to this? What im after is afunctiojn in this steps, 1- select object, etc 2 - shortcut rotate 90.
With kind regards, Victor
Replies (10)
Message 2 of 11
By using Revit , you can create a short cut for rotating a model group as you need , but you have after that to specify the "angle of rotation".
The short cut will be for the" Rotation" only .
1- Select the component (Model group for example)
2- Type your short cut (RO for example)
3-Specify your angle of rotation.
(graphically or by writing the angle at the option bar) as the attached JPG`s
Message 3 of 11
VicBerg
Thanks for your answer but this is not what i ment by shortcut, what I am after is a keyboard shortcut.
1 - Select object
2 - Keyboard shortcut exp. ctrl+R = Rotate 90 degrees.
Message 4 of 11
I suggest making the model group a family. Then the spacebar will rotate 90 degrees. No shortcut needed.
Message 5 of 11
VicBerg
Hi, I thought about that but I nee to be able to ad colors-fills to my drawings that also can be changed in an easy way but maybe this is also possible if I make a family.  / Victor
Message 6 of 11
KEYBOARD SHORTCUT brings one to the tool but doesn't access the degree field. One would reasonably expect Revit to be able to fix that so that hitting RR or RO would activate the degree field and NOT having to force user up to mouse into that field. This is one of many instances where too much mouse dragging is going on.
Message 7 of 11
ac117413
Observer
Observer
Actually Vectorworks has similar shortcut for rotating on 90 by single command which is quite good.
Message 8 of 11
There is no need to move your cursor to the degree box to type.  Select an element, initiate Rotate command, pick Center of rotation, and type the degree directly.
Message 9 of 11
bimmgr952
I encountered a rare problem.
I use a model line to draw a perfect vertical line.
But I can't draw a perfect horizontal line.
It happens to some views of the RVT file, but not all.
Message 10 of 11
bimmgr952
I tried to draw a vertical line first, and then rotate the line 90 degrees.
It doesn't work at all.
Message 11 of 11
bimmgr952
The Revit level is good, always 90 degrees.
But a model line cannot snap to a horizontal level; why?
