- Mute
- Permalink
- Report
Hi all. We just converted to v2018 and one thing that has changed a lot since v2015 is the assembled stair. In the past we never used it as it was really buggy and difficult to model precisely. We always used "stair by sketch" (which displays in Properties as just "Stair" rather than "Assembled Stair"). Now the assembled stair tool has gotten easier to use, more like "stair by sketch" used to be, where you draw each run with a single line, while "stair by sketch" is nearly impossible (at least for a conventional stair layout) since you have to draw each line individually.
So we are trying to get used to this "assembled stair" and are running into an issue I can't believe is by design. Once you have drawn the 2 runs for a switchback stair, you don't have the option of "stretching" the lower run to add risers and shrinking the upper run to delete them. If you try, you get an error that says "Bottom of run should not be lower than bottom of stairs." So you basically have to know exactly how many risers need to be each run before you begin. This is very inflexible and results in a lot of trial and error. Is this really what others are experiencing or are we missing something?
