Revit 2018.0.2 - Text Prints Oversized
zbroyles
Message 1 of 39
zbroyles
In Revit 2018, the text views fine in model but gets large in print preview, actual prints, and .pdf prints, running out of borders and off the page.  This includes text notes, room names, title blocks, and anything using text.  Huge issue since we cannot issue construction documents until this is resolved.  This appears to happen with all fonts but as a standard, we use Arial.
Replies (38)
Message 21 of 39
-FDC-
You can download and install the latest version here:
https://www.microsoft.com/en-us/download/details.aspx?id=55170
Message 22 of 39
-FDC-
Is it prossible you have a MAC with a high resolution monitor?
Look at this post:
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2018-on-windows-10-bootcamp-print-to-p...
Message 23 of 39
.NET Framework 4.7.1
Message 24 of 39
My screen is high resolution however if I lower the resolution, it still does not solve the problem.
Message 25 of 39
-FDC-
It is good you mentioned that you are on Mac, using bootcamp.
I have to admit that I don't have a lot of experience with it but someone will hopefully take over to help.
Solution should be in this post though:
It says lowering the resolution or dpi should be followed by a restart.
Success !
Filip
Message 26 of 39
Our issue ended up being a setting in windows 10  that changed the size off app fonts by default it was set t 150% larger.
There are actually two places to check these settings in windows 10.
http://www.makeuseof.com/tag/windows-10-fonts-text-sizes/
https://www.windowscentral.com/how-make-text-apps-bigger-windows-10
Message 27 of 39
The latest Windows 10 does not give you the option of changing App fonts.
Message 28 of 39
-FDC-
Did you find a solution yet ?
Message 29 of 39
No. I have reinstalled Windows 10 and REVIT 2018 and still get oversized text as per attached.
Really getting frustrated now.
It all worked before Windows 10 updated itself.
Message 30 of 39
Same boat here, can't print construction documents. Was printing with no problems before the (unauthorized) Windows update.
Message 31 of 39
-FDC-
Try changing your app fonts this way:
Right click on your screen and click on "Display Settings".
Scroll down to "scale and layout" and set to 100%.
Restart and see what Revit does.
Message 32 of 39
No dice, text is still screwed up.
Reinstalled R18, not fixed.
Side note, R16 text is still unaffected.
Message 33 of 39
Any update on this issue?
In some of our Revit 2018 files, their text keep extends over the text box! Does not have this issue on Revit 2017!!!
Message 34 of 39
Viveka_CD
Hi @Anonymous
Can you share your file and journal to test further? I can send you a private folder to upload.
Is this specific to one machine?
Looking forward to your reply update.
Message 35 of 39
Ok it turns out that, in my case,  the problem happens if a user is using the same font but in a different version.
So far updating it to the standard family font version will solve the problem, will keep monitoring.
Message 36 of 39
es1004
Message 37 of 39
Viveka_CD
Hi @es1004
Welcome to the Autodesk Community! I see that you are visiting as a new member Smiley Happy
Can you confirm if you are on the latest build?
Message 38 of 39
es1004
Yes, I am on the most recent build of Revit 2018.2
Message 39 of 39
Viveka_CD
Hi @es1004
2018.3.1 is the latest update. Can you confirm the same?
Also what PDf printer are you using? What is the font you use? Is this issue model/font specific?
