Hi everyone,
I have some issues with the 2017 Revit version. It has a student key but I doubt that's the problem.
So when I set the View Depth in the View Range, it acts like an underlay. Absolutely everything below shows including under floors and it is all in the same color tone. So basically, there is no way to know what is below and what is on the floor I'm working on.
The building I'm working on has many double height spaces, so this is absolutely vital.
Is this a fault / bug of the new version or is it something I can setup the way I want ?
Thanks in advance for your help !
Dan
Hi everyone,
Dan
Make sure you are not working in wireframe...items should only show if there are holes in the floors to let them show...else adjust the view depth so you only see what you want to see.
You're right !
I can't believe I didn't think to check the display options. Thanks for the answer !
You're right !
