I have downloaded Revit 2018 trial but an add-on I want to use is not compatible with 2018
and I need to download Revit 2017. I cannot find this on the Autodesk web-site. Is it
possible to trial an earlier version and if so where can I download it.
Solved by Viveka_CD. Go to Solution.
Solved by simona.golisciano. Go to Solution.
Hi @Anonymous,
Trial versions are available for the current release only (2018), as this is the only version available for purchase.
However, you may download Autodesk Revit 2017 using our Virtual Agent, and it will run as a Trial during 30 days. If you decide to subscribe to Revit, you'll obtain a license for the current version, though with your subscription benefits you'll also get the possibility to request a license for the 3 previous versions, including the 2017 version.
Hi @Anonymous
Please see AKN article: Downloading and installing products with the Autodesk Virtual Agent
I've marked @simona.golisciano and my post as the solutions to benefit the community. Let me know if you seek more assistance.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
