Revit 2017 Print range dialog box issue
Message 1 of 8
When we want to select the sheets / views to print and click the select button in the print range dialog box, the new window displaying all sheets / views does not show. Does anyone know a fix for this?
Replies (7)
Message 2 of 8
Hello.
I`ve noticed that you use two monitors with the Extend desktop display option on Windows. Change to Duplicate and try again the printing process. Sometimes, the dialog windows just disapears.
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
Message 3 of 8
As a single monitor we still have the same problem. Any other help would be much appreciated.
Regards
Philip Yeo
Architectural Designer
Nat. Dipl. in Architectural Technology
Massimiliano Capocaccia Architecture Studio
mc architecture studio ltd I www.mcarchitecturestudio.net
5 Tidal View Road, Ferrymead / PO Box 17685 Christchurch 8081, NZ I ph (+64) 03 384 9469
CAUTION: This correspondence is confidential and intended for the named recipient(s) only. If you are not the named recipient and receive this correspondence in error, you must not copy, distribute or take any action in reliance on it and you should delete it from your system and notify the sender immediately. Thank you
Please consider the environment before printing this email.
Message 4 of 8
Regards
Philip Yeo
Message 5 of 8
ALT + Space
M
Arrow key (try all directions)
Message 6 of 8
No sorry, this one did not work either. I have attached a screenshot of the dialog box with the buttons that are not working. This is the same problem in the attached link to forum : http://forums.autodesk.com/t5/revit-architecture-forum/buttons-in-print-dialog-box-don-t-work/td-p/3...
The Microsoft pdf writer has been deleted and it worked on one pc. The other has still no luck. We have tried to print in real paper but it still does not work too.
Regards
Philip Yeo
Message 7 of 8
Regards
Philip Yeo
Message 8 of 8
kisielewski
One thing I did do differently recently was to add a new LaserJet printer to my office.  I had this set as the default printer. Did some research on the internet and found someone with the exact same issue as me.  What they did was to change the default printer to a different one and the print dialog box worked again.  I tried the same thing and it did work.  Problem solved...go figure.
