Hi everybody,
I am using Revit 2017. All projects so far were okay except this one here.
When I am printing to pdf or blue-beam printer, everything is adjusted as usual, no big difference;
For some reason in this project each pdf come blurry and really bad graphical presentation. See attached, on the right side is my current project.
Now I am working in bigger scale (wall sections) , when I zoom in, I can see each pixel - never had this issue earlier and no one knows to tell me why.
Other projects are working fine, except this.
It may be a project settings issue?
I tried to look at line thicknesses, but couldn't figure it out.
PLEASE HELP!!!
Hi @Anonymous
Can you try exporting the sheets as DWFs and then printing PDFs?
Check HERE on more information on how to export to dwf and best practices for printing.
Share a screenshot of your print settings.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I am running Revit LT2018 and am experiencing the same problems.
Printing different sheets within the same model produces low resolution and blurry pdfs.
I have tried all the suggestions listed but without any improvement in print quality.
Hi @Anonymous
Did you try this with a different PDF printer?
Can you post screenshots?
Viveka CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Viveka CD
Viveka_CD
Did try it with PDFelement 6 and that seems to work (VAUXHALL ROAD ELEVATION#2)
The other one (VAUXHALL ROAD ELEVATION) was created with Adobe Acrobat Pro DC.
They are both prints of the same sheet.
Just for comparison the other attachment (COURTYARD ELEVATION) is from the same model but a different sheet to the above and was printed using Adobe Acrobat Pro DC and that appears o.k.
Any advice would be appreciated.
Regards
Hi @Anonymous
Can you share the file as well? I can send you a private upload folder.
Viveka CD
Hi Viveka,
Sorry for the delay in replying.
Yes if you could send me a private upload folder I will forward the model.
R. McCartney
Hi @Anonymous
No worries, thanks for checking back.
I've sent you a folder link to upload your files.
Let me know if you have trouble accessing the folder.
Viveka CD
Hi @Anonymous
Thanks for sharing the model.
I would need your most recent journal file as well to investigate this issue.
Let me know if you have any questions.
Viveka CD
Hi @Anonymous
I checked your file and your views print fine with the shadows and depth cueing.
Send me your Adobe printer settings and version you use.
Can you try bullzip PDF printer and see if that helps.
I'm wondering if you have a graphics card issue. Can you update your graphics card driver to the latest version from the manufacturer's website?
Viveka CD
Viveka_CD
Bullzip requires a subscription.
The company has already purchased Adobe Acrobat Pro DC so doesn't see the need to purchase other pdf print software.
As mentioned previously I did try PDFelement 6 and that seemed to work.
How do I send the printer settings?
I'll look into updating the graphics card driver. Incidentally the graphics card is an NVidia GeForce GT 610 - is this a suitable card for Revit?
R. McCartney
Hi @Anonymous
I did not see your journal. Can you please try again and upload to the same folder?
The print settings will be like the one in the below pic:
Printer settings
Regarding graphics card compatibility please check this tool
Viveka CD
Hi @Anonymous
Thanks for getting back. Unfortunately, I did not see your journal or print settings.
I have shared another link with you, please try uploading again and let me know if this one works.
Looking forward.
Viveka CD
Thank you, @Anonymous
I got all your files.Appreciate the quick turnaround.
While this issue is being investigated please take a look this article and Using the Adobe PDF printer
Viveka CD
