Revit 2017 not opening
Message 1 of 8
Hi All, for the first time for some reason i cannot open my student version of Revit 2017, i have sent a couple of auto generated reports to autodesk but no reply. It seems as i am a student autodesk tells me there is no online support.
As i have end of your assignments due i am at a loss, if anyone could help it would be appreciated, regards Greg
PS below is the error report
Replies (7)
Message 2 of 8
Corsten.Au
Whats the error message when you try to open Revit?
Corsten
Building Designer
Message 3 of 8
Hi Ganesh, below is the error report, however just now when I try to open the error report does not appear but Revit just continually tries to open. Seems strange as I have been using for 1-1/2 years with no problem at all.
Take 2 --- back to same pop up error now, both pop up error and error report are below
Message 4 of 8
Corsten.Au
Hi
Try using different user name.
Login to computer using another user and try to open Revit.
It it stills gives problem then its about some corruption at windows level.
I saw this post, might help you out.
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2017-not-opening/td-p/6436943
Cheers
Corsten
Building Designer
Message 5 of 8
Do you have any add-ins installed?  If so, remove them and see.
Message 6 of 8
Thanks Toan, but how can I remove add ins when I cannot open revit?
Message 7 of 8
Uninstall them via Windows' Apps and Features.
Message 8 of 8
Emptied temp folder, no luck
Run repair mode, no luck
Reinstalled, still the same
Just wont open revit at all, any other suggestions would be appreciated
