Revit 2017 Crashes on start after Windows update
Message 1 of 8
Running Revit on a student license.  It had been working fine until Windows 10 forced some updates on me yesterday.  Now, the splash screen comes up for 5 seconds or so, then disappears with no error messages.  This is the content of the Journal:
' 0:< Initial VM: Avail 134217444 MB, Used 14 MB, Peak 14; RAM: Avail 5939 MB, Used 49 MB, Peak 14
' 0:< GUI Resource Usage GDI: Avail 9995, Used 5, User: Used 3
'C 29-Sep-2016 19:45:25.402;   0:< started recording journal file
' Build: 20160720_1515(x64)
' Branch: RELEASE_2017_RTM
Dim Jrn
Set Jrn = CrsJournalScript
'C 29-Sep-2016 19:45:25.403;   0:< ->desktop InitApplication
'C 29-Sep-2016 19:45:25.411;   0:< <-desktop InitApplication
'C 29-Sep-2016 19:45:25.411;   0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Detail Items (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -24 -> 134217420 MB, Used +4 -> 18 MB, Peak +4 -> 18 MB; RAM: Avail -38 -> 5901 MB, Used +11 -> 60 MB, Peak +11 -> 60 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 717259538460
'C 29-Sep-2016 19:45:25.831;   0:< License initialization complete
' 0:< License version: 17.3.26.0
' 0:< ::0:: Delta VM: Avail -173 -> 134217248 MB, Used +31 -> 50 MB, Peak +34 -> 52 MB; RAM: Avail -74 -> 5828 MB, Used +49 -> 109 MB, Peak +49 -> 109 MB
' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 717259538484
' 0:< SystemSettings:
' 0:<                    4=multiCoreCharacteristic
' 0:<                 true=isDotNetInstalled
' 0:<    4.6.01586(394802)=dotNetInstalledVersionString
' 0:<                false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -18 -> 134217230 MB, Used +7 -> 58 MB, Peak +5 -> 58 MB; RAM: Avail -15 -> 5813 MB, Used +15 -> 124 MB, Peak +15 -> 124 MB
' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 717259538497
'C 29-Sep-2016 19:45:26.308;   0:< manage licensing
' 0:< ::0:: Delta VM: Avail -37 -> 134217194 MB, Used +5 -> 63 MB, Peak +5 -> 63 MB; RAM: Avail -69 -> 5745 MB, Used +14 -> 139 MB, Peak +14 -> 139 MB
' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 717259538498
'C 29-Sep-2016 19:45:30.109;   0:< License checkout cancel by user
'C 29-Sep-2016 19:45:30.110;   0:< License cleanup skipped
I have tried the below procedure with not affect:
06-24-2016 05:46 AM in reply to: ricktiger44
Your profile is incomplete. Please try resetting your Revit profile by perform the following:
Navigate and delete the following directories:
C:\Users\<username>\AppData\Local\Autodesk\Revit\Autodesk Revit 2017
C:\Users\<username>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2017
Open the registry editor (Start > Type REGEDIT hit enter)
Delete the following registry folder:
HKEY_CURRENT_USER\SOFTWARE\Autodesk\Revit\Autodesk Revit 2017
On those the deleted, launch Revit again.
Replies (7)
Message 2 of 8
I'm facing the same issue....
Not just Revit 2017, but all of my Autodesk Softwares..... AutoCAD 2017....
I couldnt find any solution on this. I really need it to work.
I'll follow this post....
Message 3 of 8
pendean
Community Legend
Community Legend
Message 4 of 8
@pendean,  Thanks for the reply.  I tried rolling back, but Revit still fails in the exact same manner.  Any other ideas?
Thanks!
Message 5 of 8
I had to uninstall and reinstall the entire Autodesk 2017 Suite (Revit, AutoCAD, 3DMax, Navisworks).  What a pain!
Message 6 of 8
I tried the uninstall/reinstall of everything autodesk but no luck.  Same behavior with revit.  I also tried running Revit in compatibility mode - that didn't work either.  I even tried running with elevated privileges - still no luck.  I also have Civil 3D installed and it works fine.  Revit's problem appears to have something to do with the license authentication.
Message 7 of 8
I've tried reinstalling Autodesk Programs, but no success.....
Then, I decided to format my Windows 10 and reinstall all Softwares....
Now everything is OK....
Message 8 of 8
Same problem with Revit lt 2018. Any help for this?
