How to draw curved walls in Revit??
Message 1 of 9
Hi All!
I am having an issue as I cant find how to draw a curved walls in Revit. I am not looking for curtain walls but for generic 6" walls. I was able to sketch model lines and was hoping that i will be able later to convert the lines to walls...
Anyone can help me with drawing the curved walls?
Anna
PS I am using revit 2018
Replies (8)
Message 2 of 9
ennujozlagam
@Anonymous hello, here is the simple way on how to draw curve wall in revit. hope it helps. thanks
P.S. Where did you buy your Revit 2018? lol.
Message 3 of 9
You should be able to draw walls as arcs and circles either directly from the sketch wall tool, or by picking model or drafting arcs and circles like @ennujozlagam has demonstrated.  However, if you want to draw an (partial) elliptical wall, or a spline wall, you will need to build a mass and use Wall by Face tool.
Message 4 of 9
OOps. 2017*.. Thanks! 🙂
Message 5 of 9
ennujozlagam
Hello, have you resolve your issue? Thanks
Message 6 of 9
ennujozlagam
Hello, it doesn't matter which version of Revit it is. It's the same process. Thanks
Message 7 of 9
you ok? x
Message 8 of 9
johnw
I'm trying to place a decal on a long curved wall but the decal only attaches to one of the segments of the wall and doesn't treat the entire wall as one entity. Is there a way to join all the walls so the decal spreads across the entire wall?
Message 9 of 9
ennujozlagam
hello, have you try to use paint and see if helps. thanks
or
  • n a Revit project, open a 2D view or a 3D orthographic view. ...
  • Click Insert tab Link panel Decal drop-down (Place Decal). ...
  • From the Type Selector, select the type of decal to place in the view.
  • If you want to change the physical size of the decal, on the Options Bar, enter values for Width and Height.
