Running Revit on a student license. It had been working fine until Windows 10 forced some updates on me yesterday. Now, the splash screen comes up for 5 seconds or so, then disappears with no error messages. This is the content of the Journal:
' 0:< Initial VM: Avail 134217444 MB, Used 14 MB, Peak 14; RAM: Avail 5939 MB, Used 49 MB, Peak 14 ' 0:< GUI Resource Usage GDI: Avail 9995, Used 5, User: Used 3 'C 29-Sep-2016 19:45:25.402; 0:< started recording journal file ' Build: 20160720_1515(x64) ' Branch: RELEASE_2017_RTM Dim Jrn Set Jrn = CrsJournalScript 'C 29-Sep-2016 19:45:25.403; 0:< ->desktop InitApplication 'C 29-Sep-2016 19:45:25.411; 0:< <-desktop InitApplication 'C 29-Sep-2016 19:45:25.411; 0:< ->desktop InitNativeInstance ' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Detail Items (defaultLib==\Library) ' 0:< ::0:: Delta VM: Avail -24 -> 134217420 MB, Used +4 -> 18 MB, Peak +4 -> 18 MB; RAM: Avail -38 -> 5901 MB, Used +11 -> 60 MB, Peak +11 -> 60 MB ' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 717259538460 'C 29-Sep-2016 19:45:25.831; 0:< License initialization complete ' 0:< License version: 17.3.26.0 ' 0:< ::0:: Delta VM: Avail -173 -> 134217248 MB, Used +31 -> 50 MB, Peak +34 -> 52 MB; RAM: Avail -74 -> 5828 MB, Used +49 -> 109 MB, Peak +49 -> 109 MB ' 0:< GUI Resource Usage GDI: Avail 9980, Used 20, User: Used 717259538484 ' 0:< SystemSettings: ' 0:< 4=multiCoreCharacteristic ' 0:< true=isDotNetInstalled ' 0:< 4.6.01586(394802)=dotNetInstalledVersionString ' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter ' 0:< ::0:: Delta VM: Avail -18 -> 134217230 MB, Used +7 -> 58 MB, Peak +5 -> 58 MB; RAM: Avail -15 -> 5813 MB, Used +15 -> 124 MB, Peak +15 -> 124 MB ' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 717259538497 'C 29-Sep-2016 19:45:26.308; 0:< manage licensing ' 0:< ::0:: Delta VM: Avail -37 -> 134217194 MB, Used +5 -> 63 MB, Peak +5 -> 63 MB; RAM: Avail -69 -> 5745 MB, Used +14 -> 139 MB, Peak +14 -> 139 MB ' 0:< GUI Resource Usage GDI: Avail 9973, Used 27, User: Used 717259538498 'C 29-Sep-2016 19:45:30.109; 0:< License checkout cancel by user 'C 29-Sep-2016 19:45:30.110; 0:< License cleanup skipped
I have tried the below procedure with not affect:
06-24-2016 05:46 AM in reply to: ricktiger44 Your profile is incomplete. Please try resetting your Revit profile by perform the following: Navigate and delete the following directories: C:\Users\<username>\AppData\Local\Autodesk\Revit\Autodesk Revit 2017 C:\Users\<username>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2017 Open the registry editor (Start > Type REGEDIT hit enter) Delete the following registry folder: HKEY_CURRENT_USER\SOFTWARE\Autodesk\Revit\Autodesk Revit 2017 On those the deleted, launch Revit again.
I'm facing the same issue....
Not just Revit 2017, but all of my Autodesk Softwares..... AutoCAD 2017....
I couldnt find any solution on this. I really need it to work.
I'll follow this post....
I had to uninstall and reinstall the entire Autodesk 2017 Suite (Revit, AutoCAD, 3DMax, Navisworks). What a pain!
I tried the uninstall/reinstall of everything autodesk but no luck. Same behavior with revit. I also tried running Revit in compatibility mode - that didn't work either. I even tried running with elevated privileges - still no luck. I also have Civil 3D installed and it works fine. Revit's problem appears to have something to do with the license authentication.
I've tried reinstalling Autodesk Programs, but no success.....
Then, I decided to format my Windows 10 and reinstall all Softwares....
Now everything is OK....
Same problem with Revit lt 2018. Any help for this?
