Revit 2017 crash on Windows 8.1
Windows updated and this dialogue box popped up. Tried uninstalling and reinstalling, but no luck there.
"Autodesk Revit has stopped working. A problem has caused the program to stop working correctly. Windows will close this program and notify you if a solution is available".
Anyone have this problem and have a solution?
sureshchotrani
Wellcome to the community:)
Can you please help with what graphic card is there?
Did you install the latest service pack for Revit 2017? You can find the same at https://manage.autodesk.com/cep/#products-services/updates
Is it new installation?
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
ennujozlagam
@Anonymous hello, try to untick " use hardware acceleration" in options > graphics and see if this helps. alternatively install latest graphics card driver, service packs from autodesk and windows. thanks
